50 watt 102
dcribbs1412
50 watt 102
Post by dcribbs1412 »
Had some 50 watt iron and some misc parts so I decided to
try and squeeze a 102ish circuit into a JTM style chassis. 40uf on V1 and V2,
tube loop is pretty quiet. Relay for FET with pot on front, no R/J switch
wired in Rock mode. No LNFB on V1, 100pf snubbers on V2
250kA pots for OD and Level
Running 7581's with 463V on plates biased at 35ma.
Voltages are all decent V1-203 V2-205 V3-296
Kinda diggin it with a strat more and more
Might be headed for a grab n go 1x12 cab
Darin
Colossal
Re: 50 watt 102
Post by Colossal »
Very cool build Darin. There is lot packed in there!
Re: 50 watt 102
Nice looking build and who needs more then 50w besides me :lol:
dcribbs1412
Re: 50 watt 102
Thanks guys
tracking down a pop in the FET relay.
I just found a 100 watt Marshall OT looking at me from across the room.
I will fight the urge...for now
Darin
danotron
Re: 50 watt 102
Post by danotron »
very nice...how about an audio clip?
The Blues is my Business....
and Business is good.....
dcribbs1412
Re: 50 watt 102
Thanks danotron
I'm hoping to be able to record
some clips this summer
Darin
ToneMerc
Re: 50 watt 102
Post by ToneMerc »
Looks good Darin
TM
dcribbs1412
Re: 50 watt 102
Thanks TM
roknroll
Re: 50 watt 102
Post by roknroll »
sound clips this summer
what a tease :D
tubedogsmith
Re: 50 watt 102
Post by tubedogsmith »
Man, how did you get by without using shielded wire from the FET board??
dcribbs1412
Re: 50 watt 102
roknroll wrote:sound clips this summer
what a tease :D
I ordered a Zoom recorder... I'll see if I can get some sort of clip of ridiculous wanking :)
tubedogsmith wrote:Man, how did you get by without using shielded wire from the FET board??
I actually went back and used some at this spot
I was getting a little oscillation and radio interference.
Still gettin a pop from the FET relay when I activate it.
Pop gets louder as volume goes up
Darin
dcribbs1412
Re: 50 watt 102
First try at a clip...clean with a strat
sounds like I'm in slow motion or under the influence of something :)
Darin
https://www.youtube.com/watch?v=ELfgEcI ... e=youtu.be
groovtubin
Clip
Post by groovtubin »
dcribbs1412 wrote:First try at a clip...clean with a strat
Darin
Very nice, OD channel now! lol!
dcribbs1412
Re: 50 watt 102
Here's a shot at mindless wanking
with the OD engaged...not sure the delay is helping
comments are appreciated.
Darin
https://www.youtube.com/watch?v=01ARSpo18_k
danotron
Re: 50 watt 102
Post by danotron »
very nice OD! wish my 100 watt sounded close to that
