speaker question
speaker question
will a 15 ohm speaker be ok to use with a 16 ohm speaker for a 2x12 speaker config? using a 8ohm tap
Re: speaker question
No problem. It's more question of how sensitive the speakers are and whether they will be a good match.
reply subject
I just bought a celestion blue 15 watter it's supposed to be 16 ohm but it came 15 ohm Im pairing it with a vintage 30 for a jtm45 build, thoughts on the pairing?
Re: reply subject
Impedance and resistance are two different things (AC vs. DC).harris51 wrote:I just bought a celestion blue 15 watter it's supposed to be 16 ohm but it came 15 ohm Im pairing it with a vintage 30 for a jtm45 build, thoughts on the pairing?
When you measure the resistance of a speaker with your meter it will come in lower than its rated impedance.
16 ohm speakers will measure about 15 ohms DC resistance. You have two 16 ohm speakers there. Yay!!!
P.
Use your head.
subject
I guess Im being a little confusing, My question to everyone is this: I received a 15 ohm speaker today from celestion it's supposed to be a 16 ohm but i got a 15 ohm Im pairing it with a 16 ohm vintage 30 for my 2x12 bcab my amp will be set at 8ohm is the difference in ohms gonna hurt or sound bad, Thanks
It's fine. Celestion speakers are spec'd at either 8 or 15 ohms.
A lot of speakers are noted as 15 ohm not 16 ohm and you are not going to hurt anything pairing with another speaker labelled as 16 ohms.
JTM45 into 2x12 with Celestion Alnico blue and Celestion Vintage 30 might to too bright but only one way to find out. Those Alnico's sound so good and I also like the Vin. 30.
I think I paired the blue with G12H
The wattage rating might be a problem, though. It'll get slightly more than half of the amp's output power, so something approaching 25W.
I've ran the blue 212 cab with my Stangray at high volumes and the speakers just keep on singing. I think the Stangray is 38w and a JTM45 should not be much more wattage.
