Trying to source a couple scarce parts - help?
Hi everyone,
I'm building #183 but I'm finding there are a few things I can't find. The 3-way toggle ON-OFF-ON for the bright cap switch is one. The next is the pilot lamp...where are people finding these? Finally, and this is kind of general, I need to source cover plates for Octal tube (power tube) punch outs for the 50W version. I have the chassis' punched out with all 4 tubes for 100W, but want to cover the spares up.
If anyone has sources for these (in stock), or if you have a few of these laying around and want to sell them, please let me know!
Thanks all!
Mark.
Thanks all!
Mark.
"...there are flying v's and then there are the ones shaped like peanuts..."  - my son at age 9
Malin Amplification - Boutique Amps
www.facebook.com/MalinAmplification
@MalinAmps
@MalinAmps
Re: Trying to source a couple scarce parts - help?
I think I used this switch though the part #'s have changed.
http://www.mouser.com/ProductDetail/Mou ... GEjZQWc%3d
Hm... it's like a 10 week lead time. I originally found a nice Carling min switch on Mouser but the 3-ways were out of stock.CHIP wrote:I think I used this switch though the part #'s have changed.
@MalinAmps
@MalinAmps
				dcribbs1412
I have used these
http://www.mojotone.com/amp-parts/vacuu ... 4yTz3ZOXVo
Radio shack has these
http://www.radioshack.com/product/index ... Id=2062373
Darin
Darin
Thanks, Darin! The covers are perfect.dcribbs1412 wrote:I have used these
Darin
Re the lamps, I did see those at Rad. Shak. but they were 120 V, not 6.3V (heaters voltage). But still....maybe I need to go that route.
I'm going to order me up a set of those plates!
@MalinAmps
@MalinAmps
Not sure if right diameter for your chassis, but this is what was used.
http://www.radioshack.com/product/index ... =CT2032233
Look at the 124 pics.
These are the guys I bought from Hoffman and they're way too small for the chassis punch out, unfortunately. I bought the chassis pre-punched.jelle wrote:Not sure if right diameter for your chassis, but this is what was used.
@MalinAmps
@MalinAmps
I have used these holders which allow you to use your favorite LED color.
[img:444:299]http://img-europe.electrocomponents.com ... 569-01.jpg[/img]
Also, you don't need a 6.3v LED, just a conventional LED and use the 330R and Diode.
"You feel like you're floating on a football field filled with marshmallows." -Dumble
Where do you get these guys?ic-racer wrote:I have used these holders which allow you to use your favorite LED color.
Mark.
@MalinAmps
@MalinAmps
Mark.
What's the hole size in the chassis for the LED?
I have both 3 and 5 mm bezels laying around. Would happily send one no charge if it'll help.
Edit...
Probably have a bright cap switch too.
Edit...
Deric®
Deric, if you'd be willing, that would be awesome. PM'dDeric wrote:What's the hole size in the chassis for the LED?
Edit...
@MalinAmps
@MalinAmps
