Two output Trannies in parallel?
So Is there a reason not to connect two Identical OT's in Paralell in a PP amp?
So if I had 2 8k Ot's with 4 and 8 ohm secondaries connected in paralell I could use them at 8k with 8 and 16ohm secondaries?
Re: Two output Trannies in parallel?
What are you wanting to run on the primary side? Are these PP or SE OT's?
Its Push-pull AB .I have two OT's from a PP AB stereo amp They are 8k primary with 4 and 8 ohm secondaries.
I am wanting to run them in parallel and have an 8k primary with 8 and 16 ohm seconadary
				eniam rognab
can i have your other OT? sounds like you wont need it....
So what are you saying .It's a stupid Idea?They are like little 12 wat transformers I thought maybe I could get some more headroom and bass response from the amp I'm building (6g3 deluxe)
				eniam rognab
no no, im not saying anything, just joking, certainly not a stupid question.
sounds like alot of iron though....
sorry to sully your thread cbass... you da man (jabs shoulder)
Didn't mean to come off pissy .Lots of Iron is mo good.These things cant weigh more than 2lbs a pc I Think I can handle it
						- Leo_Gnardo
I'd stick with a single OT. Plus, the output impedances won't add as you plan. Brown Deeluxe hm? Verrry nice indeed and just a pinch away from the Marshall 18W amps. Should be a winner!cbass wrote:So what are you saying .It's a stupid Idea?They are like little 12 wat transformers I thought maybe I could get some more headroom and bass response from the amp I'm building (6g3 deluxe)
For more bass, closed-back speaker cab. 15" speaker too. Hey that's a bass cab - don't tell anybody. Might consider using standard Deluxe replacement OT's if yours look small by comparison. More iron generally = mo bass.
I've got a good beefy old OT I can use. but it will need to be used with a 16 ohm cab .Buying stuff isn't really an option right now.
Is the ot in the brown deluxe the same as the tweed deluxe?
				rock_mumbles
Two OT's connected completely parallel have exactly the same turns ratio so it would still be 8k to 4 or 8 ohm ...
Oh ok I thought it would cut the primaries in half
Well i'm from missouri so I can't just take someones word.SO iguess i'll measure the turns and see  how it comes out.
				eniam rognab
i believe its pronounced "misery"cbass wrote:Well i'm from missouri
Mumbles is right. Inductance and power ratings change but the ratios don't. To change the ratio you have to go parallel-series or series-parallel, but then the impedances will change by a factor of four.cbass wrote:Well i'm from missouri so I can't just take someones word.SO iguess i'll measure the turns and see how it comes out.
You ever notice that all the badasses Clint Eastwood plays I n his westerns are outta Missourieniam rognab wrote:i believe its pronounced "misery"cbass wrote:Well i'm from missouri
