Pacosipulami Overdrive Mini
Pacosipulami
Post by Pacosipulami »
A new child is born! The "Pacosipulami Overdrive Mini" - a single overdriven channel, 6Watt all tube head based on a very famous amp and made out of an old Fender Champ AA764 chassis ;)
[img:640:425]https://dl.dropboxusercontent.com/u/100 ... SC2974.jpg[/img]
The holes for the pots were not perfectly placed - unfortunately, I got no "licence to drill" :( :lol:
[img:640:425]https://dl.dropboxusercontent.com/u/100 ... SC2975.jpg[/img]
[img:425:640]https://dl.dropboxusercontent.com/u/100 ... SC2976.jpg[/img]
Audio-clips and details will following soon.....
Cheers
Pacosipulami
:wink:
don't grow up - it's a trap!
mhartman
Re: Pacosipulami Overdrive Mini
Post by mhartman »
Nice looking build. Can't wait to hear it.
Pacosipulami
some slight changes in the circuit made! Yeah!! Now this baby rocks! No noise, no hiss, no hum - just tone!!! Clips comin' soon....
Pacosipulami
[img:1626:1080]https://dl.dropboxusercontent.com/u/100 ... st0781.JPG[/img]
clips following soon (as I got them, made by spectators at the german axe fest 2014). You can play any note and let it ring for minutes :wink:
Pacosipulami
Now together with the Pacosipulami "Silence Speaker", a compact reactive loadbox....(just a prototype)
[img:640:480]https://dl.dropboxusercontent.com/u/100 ... peaker.jpg[/img]
into the AxeFx II (used as speaker simulation and reverb fx processor)
here is a clip: https://dl.dropboxusercontent.com/u/100 ... odmini.mp3
...imagine the sound of the "Pacosipulami Overdrive Mini" amp on a real speaker cabinet! :D (still - comin' soon)
10thTx
Post by 10thTx »
Very impressive amp tone!! Thanks for sharing it.
Any chance that you could share a schematic, please?
I've posted a DRAFT unproven design. How close is your amp to this?
With respect, 10thtx
10thTx
Post by 10thTx »
Any chance that you have some sound clips without the AXE FX II ?
Pacosipulami
10thTx wrote:How close is your amp to this?
same amount of tubes, different circuit ;) It's basically a high plate "Non-HRM" ODS design with some own ideas regarding filter/tonestack circuit adjustments to my personal taste.
Funny, there is a slight similarity, a post gain filter pot - After the first tests with the design pictured above (featuring a Overdrive, Level and Mastervolume Knob, where you can see a 10pF MV treble cap), I had too much mid/high frequency content, so I ended up with a simple Hi-Cut filter in post gain position instead of the Level control, but after the mastervolume (a 250k audio taper pot with a 2.2nF cap to ground). Also changed the NFB to 22k, going straight to cathode tap of V2b
Pacosipulami
10thTx wrote:Any chance that you have some sound clips without the AXE FX II ?
The AF2 only does the cabinet simulation and reverb in the clip above, since I can't make loud noises in my rental apartment ..... ;)
that's why I build myself a reactive loadbox, so the complex frequency-dependent saturation behavior of the output stage still remains "almost the same" ;)
There are real-cab clips made at the german axe-fest two weeks ago, where I introduced the Overdrive Mini - they comin soon (as I'll receive them...).
Greetings
Pacosipulami
