Shielding high voltage wire
beasleybodyshop
Post by beasleybodyshop »
Any disadvantage to coiling wire to ground around the HV coming off the power supply to the preamp? Or is this a waste of time? I see on early silverface fender amps they do this to wires coming out of the dog house to the preamp.
Leo_Gnardo
Re: Shielding high voltage wire
Post by Leo_Gnardo »
For those who need a super low noise floor, yes a shield around the HV is good. What works even better for me is grounded copper foil or sheet behind the norm channel volume, treble & bass controls. If a little hum doesn't bother you, then don't bother.
beasleybodyshop
Leo_Gnardo wrote:For those who need a super low noise floor, yes a shield around the HV is good. What works even better for me is grounded copper foil or sheet behind the norm channel volume, treble & bass controls. If a little hum doesn't bother you, then don't bother.
So your trying to prevent RF from right after the first gain stage?
Post by Stevem »
The gain stages where the audio signal is the smallest is where the most improvement will be had by wire layout.
Old Gibson amps use to have braided shielding on the OT primary wires due to the long run that they made from almost one end of the chassis to the other!
Leo_Gnardo
Mostly 120 Hz hum here, not RF. It only seems to bother old jazz players (30 to 80 y/o) that detest hum.
mhartman
Post by mhartman »
I've seen shielded HT wires in a Fargen Miniplex. In that amp, I assumed that it was due to the fact that SE amps pick up extra noise and because the amp is often used as a recording amp.
That being said, I recently did a SE amp with a similar power section and I didn't shield the HT. My build didn't have much noise to speak of. In one of my builds, I used 1/8" sheet aluminum (bent like an L) to form a grounded shield between the power section and control panel - it worked great to eliminate a hum that was bugging me.
