IMHO, throw the MH voltage chart and power resistor rail values out the window. If you built this circuit pretty much using the same B+ voltages as MH, then it would be a valid guide. However, it's kind of a moot point since you decided to run everything 50V lower right out the gate.deiseldave wrote: Tonemerc - I had a tube rectifier slot already in my donor chassis, and figured that the lower voltage would act like a little tweak down of a VVR, and wouldn't need to change dropping resistor values from what Mark Huss had. I also saw it as a good thing to get the plate & screen voltages of the 6v6's a little closer to recommended values than what Mark's were. Is my thinking off? If so, what changes from Mark's values do you suggest.
I'm thinking the primary problem here is the low voltages on V3 pins 2, 3, 7 & 8. Anybody got ideas on the next step towards fixing that?
Thanks again.
If you followed his schematic, that 20K of resistance between the B & C power nodes is too much. You could use ohms law and run that against your own voltage chart to figure the some of the node values or you could simply shotgun the lower value, try sticking an 8.2K there first. This would raise the entire preamp voltage rail, then to tweak those two 10K 2Ws to taste.
TM
