Marshall 2204 build - slight hum
Marshall Amp Discussion
Joe Popp
Re: Marshall 2204 build - slight hum
Post by Joe Popp »
After loads of research and tons of advice I finally got the hum worked out of my amp! I want to thank everybody here for pointing me in the right direction. Some of this stuff I did not to reduce the hum but because I was going to do it anyway. Here's the stuff I changed:
- Swapped out the N.O.S. ARS filter caps for new F&T cans
- Swapped out the top hat diodes for Ultra Fast UF5408
- Swapped all of the 22AWG wire on the board for 20AWG
- Swapped out the skinny shielded wire for Lava Mini ELC
- Added a 1000pf bright cap (mustard)
- Incorporated the "Larry" star ground scheme
The amp is super quiet now. I have to play it to see if it is on! It is the quietest amp I have ever built. I am very pleased. Not only does it go to 11 but it goes there by odd numbers instead of even.
Here is the grounding scheme I used (this is for a JTM45 but I followed the same node positions):
[img:800:510]http://www.joepopp.net/JCM%20800%20Comb ... unding.jpg[/img]
Here is the finished gut shot:
[img:2989:1478]http://www.joepopp.net/JCM%20800%20Comb ... jcm800.jpg[/img]
My goal with this amp was to make a very small JCM800 for gigs in NYC. The combo box is 20" x 20" x 11" and was made by Jeff Swanson.
[img:3264:2012]http://www.joepopp.net/JCM%20800%20Comb ... 4_0001.jpg[/img]
[img:2448:2491]http://www.joepopp.net/JCM%20800%20Comb ... 4_0002.jpg[/img]
[img:2448:2511]http://www.joepopp.net/JCM%20800%20Comb ... 4_0003.jpg[/img]
[img:2448:2543]http://www.joepopp.net/JCM%20800%20Comb ... 4_0004.jpg[/img]
[img:3264:2178]http://www.joepopp.net/JCM%20800%20Comb ... 4_0005.jpg[/img]
[img:3173:1569]http://www.joepopp.net/JCM%20800%20Comb ... 4_0006.jpg[/img]
[img:3264:2448]http://www.joepopp.net/JCM%20800%20Comb ... 4_0007.jpg[/img]
[img:3264:2448]http://www.joepopp.net/JCM%20800%20Comb ... 4_0008.jpg[/img]
[img:3264:1408]http://www.joepopp.net/JCM%20800%20Comb ... 4_0009.jpg[/img]
[img:2884:2015]http://www.joepopp.net/JCM%20800%20Comb ... 4_0010.jpg[/img]
[img:3188:1490]http://www.joepopp.net/JCM%20800%20Comb ... 4_0011.jpg[/img]
[img:2448:2448]http://www.joepopp.net/JCM%20800%20Comb ... 4_0012.jpg[/img]
[img:2448:2448]http://www.joepopp.net/JCM%20800%20Comb ... 4_0013.jpg[/img]
[img:2448:2448]http://www.joepopp.net/JCM%20800%20Comb ... 4_0014.jpg[/img]
[img:2448:1502]http://www.joepopp.net/JCM%20800%20Comb ... 4_0015.jpg[/img]
[img:2448:2093]http://www.joepopp.net/JCM%20800%20Comb ... 4_0016.jpg[/img]
statorvane
Post by statorvane »
Very clean! Nice build. Thanks for the photos!
Looks very nice! I guess you have had it running previously, but I'm wondering how hot it will get inside, and the OT is likely to get very warm being directly above the output tubes, no?
Joe Popp
Post by Joe Popp »
martin manning wrote:Looks very nice! I guess you have had it running previously, but I'm wondering how hot it will get inside, and the OT is likely to get very warm being directly above the output tubes, no?
Marshall has used the very same configuration for years as seen in these pics of the Bluesbreaker and a 1979 JMP. The 1962 Bluesbreaker reissue still uses it. I previously had a JTM45 Chassis in the cabinet with no trouble whatsoever. But thanks for looking out for me!
[img:640:414]http://bluezzbastardzz.kilu.de/marshall_back.jpg[/img]
[img:1333:1000]http://www.maverick-music.com/wp-conten ... aa-084.jpg[/img]
ampgeek
Post by ampgeek »
Congratulations on running that hum to ground (pun intended)! :lol:
Where did you end up landing that pesky presence pot ground?
I was wagering that was the primary issue based on past experiences.
Awesome looking build Joe!
Dave O.
sepulchre
Post by sepulchre »
Man, that's a work of art! Beautiful build!
Joe Popp
Post by Joe Popp »
ampgeek wrote:Congratulations on running that hum to ground (pun intended)! :lol:
Dave O.
Dave,
I actually moved that twice (didn't help in my previous schemes) before redoing all the grounding! I believe I came upon some of your posts? I am sure I had other issues but I ended up with the presence ground to node 3 as in the JTM drawing.
ampgeek
Post by ampgeek »
Guess that I would have lost that bet. It wouldn't be the first!!
I sometimes feel like I have forgotten more than I currently know as I am a simple hobbyist at all of this so I can't recall if I ever posted on that specific issue. However, I know that I have faced it in the past.
I have pretty much settled on Merlin's approach to grounding whenever possible as it has never, ever let me down.
Did you do a very comprehensive comparison between VVRs and attenuators in Marshall circuits some years ago? The article/soundclips were very informative and useful.
If it was you and you still have that up, please consider posting a link here as I am sure that many others would be very interested in seeing/hearing it.
Glad that you are hum free!!
Dave O.[/u]
rogb
Post by rogb »
That is one sick build! Fantastic!
Congrats on tracking down the hum.
LARRY for me all the way with Marshalls.
Otherwise Dumble style does it for me in Fender builds
dcribbs1412
Post by dcribbs1412 »
Congrats Joe Popp
outstanding build...thats got to be a awesome grab n go amp 8)
rogb wrote:LARRY for me all the way with Marshalls.
+1
Darin
Joe Popp
Post by Joe Popp »
Thanks for all of the complements guys. I couldn't have done it without help from so many people on these forums. Seeing other builds inspires me. I am humbled.
Joe Popp
Post by Joe Popp »
ampgeek wrote:Guess that I would have lost that bet. It wouldn't be the first!!
Dave O.[/u]
This was not me Dave! Sounds cool though...
maxwedge
Post by maxwedge »
Awesome job on that and I like the use of the Neutrik Powercon socket!
Beautiful! 8)
Scott
Lummox
Post by Lummox »
Echoing what the others have said, that's a beautiful build ! So clean you could eat off of it !
