Dumble problem
Dumble problem
Hi,
I have made a #183 clone, But now I have a problem and need some advice. Someone used an effects pedal with a to large output and now the fine detailled sound of my amp is almost gone. Is this just the preamp tubes, or do I have a bigger problem?
It's all fuzzy and raspy now. terrible.
Thanks !
Thanks !
groovtubin
Re: Dumble problem
does guitar plugged into the FX RETURN on back of amp play ok?tubey wrote:Hi,
Thanks !
jim@Omegaamps
amplifiednation
Re: Dumble problem
When did you build the amp? How long did it work well?
Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
Re: Dumble problem
Just a stab in the dark but are you plugged into the FET input with high output pickups on your guitar? I plugged my paul into my FET input once by accident and thought something was wrong with the amp, which sounded hash and raspy. After I plugged back into normal input it was as usual.tubey wrote:Hi,
Thanks !
Just a quick guess.
Re: Dumble problem
Thanks guys for your comments.
I build the amp about six months ago. It worked perfect until someone used a ZVEX super hardon with max volume.
It's the regular input. Thanks for suggesting the FET, it could have easily been that. But I used the normal input.
I'm going to try that effects return ( thanks Jim ) then I could isolate the problem in the pre or power amp. I was bright enough to built the amp, but not very bright in fixing these problems.
I hope its just the output tubes or some small component I can exchange.
amplifiednation
Re: Dumble problem
I was thinking it might be a bad solder joint that might have been exposed by the high level into the amp. Stranger things have happened. Try isolating the problem, it's probably going to be in the preamp...also i would swap some tubes
Amplified Nation
@ampnation
@ampnation
Re: Dumble problem
There shouldn't be anything to go bad between the input jack and the first grid except the 22k resistor. I have read of grids melting but have never experienced it. Try replacing the first preamp tube.
"You feel like you're floating on a football field filled with marshmallows." -Dumble
Re: Dumble problem
A quick check of the tube voltages will tell you if a resistor/capacitor/tube has gone whacky. While you're in there, use your probe to wiggle the wires and whack the relays. Another possibility is a blown speaker...
Re: Dumble problem
Thanks for the advice. I'm going to try these things. I have a lot of measuring to do. I hope I will find the problem quickly, because the amp sounded like a million dollars.
The only way I could have ever build the amp was with all the great info on this site and all the contributions of you guys.
Re: Dumble problem
So. I've checked everything. All the voltages are OK. The bias is exact how I adjusted weeks ago. Is it possible the NFB resistor is blown?
Is there a way to measure if the OT is damaged?
I feel I miss a great deal in bandwith, with a bit of a fuzzy sound. Swapped the preamp tubes, no difference.
Should I desolder the NFB resistor and check?
I still have to try to plug in the power amp and hear what happens.
Thanks for the advice !
Re: Dumble problem
DId you try with a different speaker? Perhaps the speaker is blown....
Re: Dumble problem
It does sound better with my own 4 x 12 at home. Still I feel a loss of bandwith. I'm wondering if it's possible that the NFB resistor is blown. All the voltages are OK. Maybe I got the EL34's worn out, or did I wreck my OT and is there a way of checking this?
It's great to have made this amp, but I have no experience in tube amp problem solving. I have solved some small things in the amp, like switching the primary wires of the OT.... squeel.
groovtubin
Re: Dumble problem
Find some old capitol radio engineering books from the 50`s n start learnin!tubey wrote:It does sound better with my own 4 x 12 at home. Still I feel a loss of bandwith. I'm wondering if it's possible that the NFB resistor is blown. All the voltages are OK. Maybe I got the EL34's worn out, or did I wreck my OT and is there a way of checking this?
jim@Omegaamps
Re: Dumble problem
Tubey, where are you in the Netherlands?
Re: Dumble problem
I'm located in Hengelo......
