Can I do this?
lgehrig4
Can I do this?
Post by lgehrig4 »
I blew fuse and power tubes in my new Concorde build. It was working fine with JJs, but I wanted to try a pair of old Winged Cs that I had and I guess they weren't up to the 500V ;)
Anyway, here's my question. I wanted to remove the power tubes tonight and burn the amp in using an ipod. I don't have a 750mA fuse handy, only a 1A. Can I use the 1A just for this burn in or no fuse at all since there won't be power tubes plugged in?
Thanks!
Paultergeist
Re: Can I do this?
Post by Paultergeist »
I will confess that I do not understand the logic behind "burning in" an amplifier with no power tubes installed.
Can you explain the rationale a bit more?
lgehrig4
Re: Can I do this?
Post by lgehrig4 »
It's not burning in the entire amp, just the caps in the preamp and I guess as far as the signal transfers. I learned about it either here or on the gear page.
I couldn't speak a out it technically, but I could vouch that it did make a difference with my last build and so far with this one before I blew my el34's.
Blackburn
Re: Can I do this?
Post by Blackburn »
You can probably forego the B+ fuse with no power tubes installed and not worry. The pre tubes tend not to be enough of a hazard to take anything out with them if they go. With the power tubes installed, 750ma or 1a won't make much of a difference because if one goes, it'll likely pull more than 1a.
Zippy
Re: Can I do this?
Post by Zippy »
lgehrig4 wrote:It's not burning in the entire amp, just the caps in the preamp and I guess as far as the signal transfers. I learned about it either here or on the gear page.
Hmmm, that sounds like something you're more likely to "learn" on the Gear Page... 8) :lol:
matt h
Re: Can I do this?
Post by matt h »
(deleted)
Paultergeist
Re: Can I do this?
Dumb question......what does "CF" stand for?
Re: Can I do this?
cathode follower
Paultergeist
Re: Can I do this?
Thank you, Sir!
Jana
Re: Can I do this?
Post by Jana »
Cat Fight
Cheese Fries
What?
Re: Can I do this?
CF = cobble fuck. cluster fuck is acceptable also
Invertiguy
Re: Can I do this?
Post by Invertiguy »
How about Chicken Fried? 8)
lgehrig4
Re: Can I do this?
Post by lgehrig4 »
Sorry to interrupt the fun. I emailed a respected builder today about this and the answer I got was new to run the amp without tubes. Not sure where I found got the idea from in the first place, but lesson learn to verify information unless I am familiar with the source.
printer2
Re: Can I do this?
Post by printer2 »
Your voltages will be artificially high if you run your amp without the power tubes. Just play your amp normally, this whole capacitor burn in thing is overrated.
Blackburn
Re: Can I do this?
Post by Blackburn »
printer2 wrote:Your voltages will be artificially high if you run your amp without the power tubes. Just play your amp normally, this whole capacitor burn in thing is overrated.
+1000
The amp wants you to play it and it knows when it's being lied to with a signal generator... :wink:
