Small FX loop for clones
Dumble schematics, designs, pictures. Only members may post files here.
heisthl
Post by heisthl »
My weekend project - Using a 5x7x2 Hammond box with Fender stand-alone reverb Transformer and choke. I'll update when it's tested.
EDIT 12/17 updated attachment
www.RedPlateAmps.com
Normster
Re: Small FX loop for clones
Post by Normster »
That is SWEET!!! Keep us in the loop. (Sorry, I couldn't help it. :lol: )
fabiomayo
Post by fabiomayo »
I don't even use effects loop, but you got me wanting one of those. :lol:
Pretty cool. Normster said right, keep us posted :wink:
All the best
glasman
Post by glasman »
FWIW, the two 10 meg resistors can be replaced with a single 22M. Also if space is an issue with the .22uf, a .1uf can also be subbed in that location. My less than dogears ( :D ) could not detect a dfference in performance.
Gary
About 5 miles south of I-94
www.glaswerks.com
heisthl
Post by heisthl »
Well it works great - I made a couple of changes and re-posted the attachment in the top of the thread. Plates at 295 and 200. I'll post some pictures soon. The PITA on this one was I had to mount the board on the bottom cover which made for some longer leads than necessary. On the next one I'll rearrange a few on board components so I can cut a circle in the phenolic and mount the board around the tube socket which should result in very short leads.
Robert
Post by Robert »
Thanks for posting! That is the first layout with power supply I've seen for the Dumbleator. Several have suggested it improves the tone of the amps. What's your opinion?
I look forward to your pics.
heisthl
Post by heisthl »
It does and it doesn't - the amp has to sound good or the loop won't do anything for it. The loop really doesn't distort much even on 10s with no external FX plugged in. What the loop does let you do is run more treble through the OD and smooth it back down which allows another variation in OD sound complexity. On the clean side a similiar effect takes place - that extra gain stage can give a little more sustain and rounder tone. Unless you have a really crappy effects unit I would doubt you ever need the bright switches.
heisthl
Post by heisthl »
Here's some pics - before you groan at the long leads realize that this unit has 0 noise. I wouldn't do this again - instead I would redesign for an internally mounted board.
fabiomayo
Post by fabiomayo »
Looks good. The size is really impressive.
Tonegeek
Post by Tonegeek »
What tube are you using? thanks, whit
Pitcher Amplification
http://pitcheramps.com
heisthl
Post by heisthl »
Initially a 12AX7 but now I've been using a 12AT7 - I was worried about working the AX too hard on the first stage. The loop still has plenty of headroom with the AT - I suppose a 12AU7 would work well too or ideally a 12DW7 would give you the best of both worlds.
JimiB
Post by JimiB »
what did you use for the choke?
novosibir
Post by novosibir »
JimiB wrote:what did you use for the choke?
Fender 22707 - the Princeton/DeluxeRev choke.
Larry
Larry's Website now with included Pix's Gallery
heisthl
Post by heisthl »
I should point out that since building this one I've learned that the V1a and V1b supply points should be swapped. The cathode follower side should be fed less voltage than the side with the 100k plate resistor. Also the 10k/1.5k string on the cathode should be raised to 27k/1.8k
jelle
Post by jelle »
'Also the 10k/1.5k string on the cathode should be raised to 27k/1.8k.'
Is this actual Dumbleator info? Or a member's tweak?
Jelle
