Tech Tip
Jana
Tech Tip
Post by Jana »
If you're working on an amp and snip off a lead from a resistor and it gets sucked into the carpet, the fastest way to find it is to walk barefoot on the carpet. You can look for it on your hands and knees for hours and not find it, but take off your shoes and it will magically appear.
Tip 2. The hemostats you use for building amps also work great for extracting the piece of wire from your foot.
What?
Re: Tech Tip
:lol: Too funny Jana and yes funny how I've had to room wire clippings from my feet before too. :)
Bob S
Re: Tech Tip
Post by Bob S »
Yep - been there & done that :shock:
Tip 3
When turned on, a soldering iron tip is hot.
Contact between a hot tip & skin should be avoided.
Why Aye Man
EtherealWidow
Re: Tech Tip
Post by EtherealWidow »
Also, no matter how seemingly convenient, avoid the temptation to hold what is being heated with said iron. Heat transfers.
Leo_Gnardo
Re: Tech Tip
Post by Leo_Gnardo »
Bob S wrote:Tip 3
Corollary 3A: Do not solder while wearing shorts (or less.)
Recommended to wear jeans/dungarees.
Solder drips hurt!
echuta13
Re: Tech Tip
Post by echuta13 »
Welding with sneakers on is a no-no too unless you like doing the indian hot-foot dance. :?
If you can't be a good example, then you'll just have to be a horrible warning.
gui_tarzan
Re: Tech Tip
Post by gui_tarzan »
And if you're welding overhead, don't wear a belt or button your shirt cuffs.
eniam rognab
Re: Tech Tip
Post by eniam rognab »
carpet in a workroom? fan-saaaaay!
pardon me but do you have any grey poop-on? i need to hide my amps secrets :lol:
mhartman
Re: Tech Tip
Post by mhartman »
Law: You will get the OT secondaries backwards. Don't fire up for the first time while the wife and kids are sleeping (unless you leave the neg feedback disconnected).
Jana
Re: Tech Tip
Post by Jana »
Carpet in my workroom--yes indeed. My workroom is the living room. The chassis drilling station is the kitchen floor (linoleum, I've only drilled one hole in it). My workbench is a dining room table imported from Europe (nothing fancy, just solid wood). Gone are the days when I had a dedicated workshop. But, it's better this way--I have learned to clean up and put tools away regularly--well, sort of. I have a spare bedroom that I just shovel every thing in there.
What?
Tillydog
Re: Tech Tip
Post by Tillydog »
gui_tarzan wrote:And if you're welding overhead, don't wear a belt or button your shirt cuffs.
And cover your ears!!
TUBEDUDE
Re: Tech Tip
Post by TUBEDUDE »
Funny you mentioned the found lead, I just had that happen to me. Unfortunately I was wearing new thick Thorlo socks. The lead would stab me intermittently, and each time I removed the sock I couldn't find the offending nib. Finally decided to run it through the laundry, problem solved. Couple days later I'm at work and getting intermittently stabbed during the day. The dam thing is still there! Finally got home, tried an uber strong magnet, magnifier and packing tape. Still no joy. Had to throw it out and used the other sock to polish shoes. Wasted $18 on that pair of socks. I wish i had found it barefoot!
Baxtercat
Re: Tech Tip
Post by Baxtercat »
A corollary is: if it drops into the chassis, the way to find it is to turn on the amp and look for sparks.
Guitar Bob
VacuumVoodoo
Re: Tech Tip
Post by VacuumVoodoo »
When you put your solder wire aside for a few seconds don't look for it where you are sure you put it. Start looking somewhere else at once. Saves a lot of time and frustration.
This is also valid for any tool.
Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
Jana
Re: Tech Tip
Post by Jana »
Very true Aleksander.
Also, if you try to solder and the solder wire just isn't melting like it should be, it's probably buss wire.
What?
