I'm new here. Have been lurking for the past week or so, and I think it's time to make a post. I ordered the Express kit from triodeusa. They provide a layout, which is pretty much the same as the one here, but they don't provide anything else like instructions or a schematic. In my many google searches for advice, I found this site. It seems like you guys have way more trainwreck specific info than anywhere else on the web, so now I'm here.
I always try to figure things out on my own and will try to minimize questions. But I'd like to run things by you guys as I go.
First of all, I guess I should give a little info about myself and my hopes/expectations of the amp. I play mainly metal and heavy rock. My side project website is alltoash.com. I'm not concerned with keeping the amp 100% traditional. Just want a good sounding high gain amp.
This is my first amp build, and will be my first tube amp. (I know, not the best one to get started on). But I have worked with small electronics as a hobby for a while now, as well as being an instrumentation tech for my job. I regularly work with 480v 3 phase power. So I'm used to being careful around high voltages. I know to make sure caps are discharged when working anywhere in the circuit.
I can read a schematic, and check everything back and forth between that and the layout. I've read the building guide PDF here. And also read a bunch more on these boards. The main thing with building tube amps that I don't have experience in is how much the placement of wires matters. I do have to take things like that into consideration somewhat in electrical cabinets when running say a 24vdc 4-20ma signal near 480vac power. Never running wires with vastly different signals parallel with each other. Shielding when needed. So hopefully that experience will be of some help.
So I'm hoping that with everything I've read here for advice that I can work this out. I'll make sure to document things. I can take good pics if anyone ever has questions or wants more detail. And I'll absolutely be sure to share sound clips/videos with you guys once it's done. Right now, I'm still waiting on a few more parts from triode, so won't possibly be done for at least a few more days. Probably longer.
Anyway, sorry for the long post, but I figured that I'd use this as my build thread, and wanted to introduce myself.
My first question is what do you guys say about my bias wiring? (images attached) I swapped the capacitor and resistor to make it easier to fit the pot where the turrets are. This should electrically be the same, but I know that there can sometimes be more than that with an amp like this. Do you guys think I'll be OK with it how it is?
Thanks, and I'm looking forward to sharing my build with you guys.
