I unhooked my 6.3V Xfmr tap for the heaters, and powered up the heaters with a 6V lantern battery to see if it eliminated the hum, which it did. That's how I isolated it down to something with the heaters.
zelenko wrote:Hello, im having the same issue, buzz when master is engaged, the clean channel works good! i doubled checked everything and there is no mistake to the wiring!
did u solve your problem?
thanks in advance
zelenko wrote:tried >( the same hum does not go away any other clue? i measuerd all voltages from the schematics and they ar all the same +- few volts!
