Here are my findings:
Code: Select all
amp            watts  power section     plate voltage
Twenty          3.2   2x 6V6 cathode
Element 79      7     2x EL84 cathode   366
Hammond Stout   7     2x EL84 cathode   340
Shasta         12     2x 6V6 fixed      380
Rocket Dog     15     4x EL84 cathode
AceTone        17     2x 6V6 fixed
Fiddy TFL      35     2x EL34 fixed
Fiddy V3       46     2x EL34 fixed
PRO-100        63     4x 6L6 fixed
JCM 800 2203   72     4x EL34 fixed
First, I'm surprised the cathode biased amps are so much lower in power than fixed. I have no comparisons to make from this list (I don't have any fixed-biased EL84 amps). Would you expect the Rocket to be 15 watts? Would you expect cathode biased amps to be HALF the power of fixed?
Second, I obviously have issues with the "Twenty".
