Slope resistor switch mod
Now that I finished my 6V6 plexi build, I have an unused spdt switch on the back. I'd like to wire it up to switch between a 33K and and a 56k slope resistor. Seems easy enough right?
Owner/luthier of Flintrock Guitar Shop, Flint, MI.
Owner of Hawkins Effects Pedals
Re: Slope resistor switch mod
Look here under 3in 1 tone stack. You can use the part you need for your switch o start a whole new idea.
http://home.comcast.net/~mamp17/Misc%20 ... 0Info.html
Real men go variable lol.
Have you considered putting it on a pot in series with the slope. Putting a 25k there would give you both of those sounds and everything in between.
I did consider the pot but the switch is already there, wouldn't be much to make the hole bigger and put a pot in there I suppose. But its also another control to dial in, sometimes simple is good. John do you find yourself using multiple settings?
Smokebreak
To just switch between 2 values I would put the bigger target value on the board and switch in a parallel resistor to get it to the smaller target value.
A 56K and an 82K will get you there.You can use just two lugs on spdt(or use spst)Run the 82K acroos the middle and an outer lug, and wire each end of the 56K to the same lugs. The switch will short the resistor or put it in parallel. Put in a dpdt and you can switch out the treble cap at the same time too!
Yes all the time I really like the 39-47k range. The cool part of using the 25k pot is you would basically be where you want your fixed values to be at the beginning and end of your pots rotation. It's a useful control I picked up here.flintrock wrote:I did consider the pot but the switch is already there, wouldn't be much to make the hole bigger and put a pot in there I suppose. But its also another control to dial in, sometimes simple is good. John do you find yourself using multiple settings?
So for the slope pot I'd use one end and the center lug as my connections?
Could I move the 33K resistor to right on the pot as well freeing up some board space?
Variable slope sounds good just visualizing how to do it...
Thanks....
Thanks....
Here's what I did in my JMP50 style amp:
GKT
Nice! Thanks...
Nice! Thanks...
I was out of 25k pots so just used the existing switch to flip between 33k and 48k and I like it a lot. Works for me! I think on my next build I'll incorporate a front panel mounted pot.
Sorry I'm just getting back, glad you figured it out and that you like it
Looking forward to cranking it up tomorrow!
You'll love it. Thanks to reeltarded I'm hardwired to add it and a variable resonance to everything I do now.
beasleybodyshop
I was about to say, wheres Miles? He would be all over this topic loljohn l wrote:You'll love it. Thanks to reeltarded I'm hardwired to add it and a variable resonance to everything I do now.
The mod sounds awesome. You can really get an amp dialed in based on whichever style of music your playing.
