Glaswerks Zingaro
- glasman
Glaswerks Zingaro
Hey if any of you are in the Austin area.  Stop by Austin Guitar House,  OZ is handling my amps now and if you want to take a look at one he has a 25 Zingaro on hand.
Gary
									Gary
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
- glasman
Re: Glaswerks Zingaro
A few ZIngaro pictures if you have never seen one.
Entire amp is built on two board. main and power supply. Includes Active loop and no-load reverb.
Gary
Gary
www.glaswerks.com
www.glaswerks.com
Very nice cosmetics, Gary. But now you've mentioned the boards, I want to see!
						- glasman
As requested
This is from the protoype. Built in a Princeton chassis.
Gary
Gary
www.glaswerks.com
www.glaswerks.com
Nice work Gary! Does the Pcb save you a lot of work when building?
Nice to see the layout of components is recognisable compared to eyelet lay-out often seen in this part of the forum .
No push/pull pots?
Very compact and complete amp!
No push/pull pots?
- glasman
In the end, not really. Still have to measure, form install and solder every part lol.erwin_ve wrote:Nice work Gary! Does the Pcb save you a lot of work when building?
No push/pull pots?
Next gen of the boards I will modify slightly, splitting out a couple of grounds and other small tweaks.
But it does make the amps consistent. And that is the nice part.
With all the hardware and trannies in place it takes about 30 minutes to install the power supply board, maybe less and around 1 hour to install the main board between sipping on coffee and procrastinating.
Assembly time for the mainboard take about 1 hour or so, power supply takes about 2 hours and that includes all of the power supply wire to main board and ground.
Probably have 200 hours into the board design, but it was worth it in the end.
I offer them in a Sky, , 70's,HRM, DeLeo and other custom tunings.
I can also add a switchable FET preamp if the customer desires.
Gary
www.glaswerks.com
www.glaswerks.com
- glasman
And Yes NO pushpull pots in the amp.
Notta one.
Gary
									Notta one.
Gary
www.glaswerks.com
www.glaswerks.com
				dcribbs1412
Very sweet little amp package
congrats on Austin Guitar House
- glasman
Thanks much. Its nice when they come to you....dcribbs1412 wrote:Very sweet little amp package
Gary
www.glaswerks.com
www.glaswerks.com
Looks great Gary!!   Zingaroo is at the top of my list of amps I'd buy if I wasn't happy with my own builds!!!
									Deric®
