Opinions of half power switch
				Charlie Wilson
Hello everybody, I am new to the forum and am about to begin my first Dumble build. I think I am going to do a 100w low plate classic tone stack. I guess that is a #124 in it's original state. I play Fender guitars and I think a more Fenderish tone stack will be what I want. I just received one of those nice CE Pedals chassis and I notice it does not have a spot for the half power switch. I also notice that some of the other chassis do not have them either. I guess I could drill a spot for one but I don't think I will try to squeeze it between the stand by switch and speaker jack. I looked at a lot of pictures of 100w Dumbles and they all seem to have it, so is it safe to assume that builders just don't like them that much?
						Re: Opinions of half power switch
I have played a half dozen amps with half-power switches, the ones that just ground two of the power tubes. Did not find it useful at all.
They're a good selling feature if you end up eventually selling the amp.  I never use half power on a Dumble because the Master works so well.  But, as a marketing tool, a half power switch is the bomb.
				Charlie Wilson
OK, I think I can stop obsessing about the half power switch and move on to what color the resistors are going to be.
Resistor colors that sound best
Red
Blue
Brown
Tolex that sounds Best
Purple--You can't handle the TONE!
Black
Green
Orange
Wimpiest
Red & Pink!!..
									Red
Blue
Brown
Black
Green
Orange
Wimpiest
Red & Pink!!..
				PaisleyTube
Resistors sound better if you seal them in a ziploc bag with angel hair for at least 48hrs.talbany wrote:Resistor colors that sound best
Red
Blue
Brown
Black
Green
Orange
Wimpiest
Red & Pink!!..![]()
TM
				amplifiednation
Suede sounds better than tolex
									Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
				Charlie Wilson
Did Alexander D. get his angel hair from Radio Shack?
						- JazzGuitarGimp
Nope, he gets it at Safeway. It's in the pasta section....Charlie Wilson wrote:Did Alexander D. get his angel hair from Radio Shack?
1/2 power for a 6db drop in volume......and tone.
It is a skinnier and more saturated tone that works well in live situations. Nice to have on an ODS or Overdrive Reverb. A well built ODS is a huge sounding amp, and can sometimes be too big in the mix. Making it skinnier is not always a bad thing.
ToneMerc wrote:Resistors sound better if you seal them in a ziploc bag with angel hair for at least 48hrs.talbany wrote:Resistor colors that sound best
Red
Blue
Brown
Black
Green
Orange
Wimpiest
Red & Pink!!..![]()
TM
That's no secret..Everything get's better with a little pasta..
Put me down for the Non Skinny tone
