It's a 2 * 10 combo with a pair of 6V6 for the output. It has a high and low input with the triodes bridged internally.
JTM 15
JTM 15
A new build--a JTM 15 (thanks Leo Gnardo for the name).
What?
- Reeltarded
Re: JTM 15
OMG omg I love that!!
Re: JTM 15
Thank you!
I will try to get some better pictures tomorrow when there is better light.
What?
- Reeltarded
Re: JTM 15
It is basically a JTM with 6v6 though?
Chat it up, yo!! I like twin 10s.
Re: JTM 15
Bad ass! Voltages? Layout? Schematic? Trickery? Sharpie colored white ground wire?
Re: JTM 15
I think so. I get the versions mixed up.
It has a 12AY7 for the first tube (which is more like a bassman).
The first tube is shared cathodes 820R/320uf.
.027uf coupling for the normal channel.
.0022uf coupling for the high treble channel with a 100pf bright cap on the pot.
270K mix resistors--no treble peaker cap on either.
56K slope, 250pf treble cap.
Old style 5K presence pot with .1uf cap--47K feedback to the 8 ohm tap.
395 volts on the plates (higher than I wanted it--I would like about 360).
6600 ohm Deluxe OT.
A pair of Celestion Vintage 10 (16 ohm).
Um--what else?
6600 ohm Deluxe OT.
Um--what else?
What?
Re: JTM 15
Lots of white wire for grounds.
What?
Re: JTM 15
15 watts clean, 21 watts max with JJ tubes.
11 watts clean, 15 watts max with tung sol RI tubes.
What?
Re: JTM 15
That looks vary nice
- Reeltarded
Re: JTM 15
AY? AWWWW
Re: JTM 15
Double Welp,
A 12 AX7 sounds much better in the first tube.
Back to more wine, tube rolling, and noodling.
What?
Re: JTM 15
Awesome! Thanks for the spec report! Bet it sounds great. Love the JTM sound. Like to hear hit go. Noodles go great with wine! (alas, it's the weekend and I have no wine
- Reeltarded
Re: JTM 15
haha
