Mechanical/magnetic power transformer hum
I have a friend's 1981 Jim Kelly FACS head. It has a high level of hum. No so bad that it would prevent you from playing with a live band, but very obvious and obnoxious when playing alone.
The power transformer is clearly to blame. I removed ALL the tubes, and hooked up a speaker. Even in standby, you can hear the hum in the speaker.
But before I report to the owner, I want to rule out filter caps. During my test, above, the output transformer's primary's CT is connected to HV. Is there any chance bad filter caps could inject ripple into the OT via its CT?
- Reeltarded
Re: Mechanical/magnetic power transformer hum
I remember some of them doing that.. IN 1981.
How about the bias cap? if this amp is fixed bias.
It's probably the orientation of the transformer. Marshall goofed with the JTM45 reissue and had the transformer oriented wrong. I have spun a few of those 90 degrees and no more hum.
Just because it's factory built doesn't mean they did it right.
- Milkmansound
insert snarky CBS Fender commentsJana wrote:Just because it's factory built doesn't mean they did it right.
Considered the orientation, but looks correct. However, must acknowledge that I can hear that damn PT humming like a bad fluorescent lamp ballast even with no speaker plugged in. Made sure nuts are tight. I can feel the vibration with my fingers.
@Mark: I think we can rule out the bias cap, since this problem exists with NO power tubes installed. Agree?
Yes it would definitely show up, so rule that out.xtian wrote:@Mark: I think we can rule out the bias cap, since this problem exists with NO power tubes installed. Agree?
I like what Jana said didn't know about that
Did you get anywhere w/ this Xtian?
I was just coming on here to ask the same thing.
I've got the same symptoms w/ an old Bell 35 watt PA amp [cathode biased].
Speaker hums with no tubes in the amp.
What would cause this, a short in the PT? or in a filter cap?
[edit, I'll try moving the OT. It is kinda close to the PT.]
Guitar Bob
No, didn't get anywhere. Owner did not want to pursue.
