Sockets for relays?
Sockets for relays?
I'm going to be rebuilding my radio tube amp (https://tubeamparchive.com/viewtopic.ph ... highlight=), too many changeshave resulted in all the caps having battle scars from the desoldering iron, and I expect that's why 60 hz hum is now creeping back in. I needed a better layout anyhow.
So I'm revisiting the location of my relays - moving them inside the chassis on a PCB. I can mount them on wide chip sockets for ease of maintenance - is that a good idea, or would they tend to fall out? Are there any best practices around this?
Re: Sockets for relays?
I have successfully installed many dozens of relays using the socket type shown here:
http://www.hoffmanamps.com/MyStore/perl ... =141403167
They relay is held very, very tightly in the socket.
I think that sockets are manufacutred by MilMax(?). Sorry that I don't have a Mouser/other P/N at hand to share...but...I am sure someone has that right on the tip of their tounge!
Our brother here, Colossal, sells a very sweet set of relay PCBs that you might want to check out.
Good luck,
Dave O.
Good luck,
Dave O.
If it seems a little sketchy, you can put a drop of the dreaded silicone RTV on each end to hold it.
Thanks for the nice plug Ampgeek!
The relay on my board is indeed socket-mounted so in the case it should fail in service, it can be quickly replaced. Haven't had any reports of failures yet though. The socket is a Mil-Max 16 pin and the Mouser part ID is: 575-199316
Yep, that is the socket I use and it grips the relay pins very securely, no fear of falling out.
But if you want added insurance, just put a dab of silicone on each side of the relay and socket.
- Milkmansound
What about octal socket relays? You can use a tube socket!
My pleasure mate. Love those boards...all the right options make them really flexible!
I couldn't imagine having to put an adhesive on the relay. Quite the contrary, I get nervous whenever I have to pull one out because they are so tight! I use a stout dental tool to pry it up evenly (in small increments) at each end. It requires more leverage than you would initially think.
Dave O.
Dave O.
Those are great sockets - there's just enough room under them for a small zip-tie. Much cleaner than any adhesive.
