titanicslim wrote: I think my next T'wreck will feature double decker boards for those caps, like I've seen others do.
This LO was just meant to be a place to start. When you're building an amp for yourself, there's no right or wrong if it suits your ears. I plan to stack 20's on 40's as Ken did. I think, after discussing it with Dana and Allyn, the hookup on the filter caps is authentic.
The consensus seems to be that, since Twrecks walk that fine line between tonal bliss and anarchy*, lead dress is very important. Builders like Allyn, Dana, and others have there lead dress pattern down cold. I, on the other hand, will likely be in the chassis with chopsticks like a Chinaman on an order of mu shu pork, figuring mine out
 But, then, that's the learning process, isn't it
*Conservative as I am, a Trainwreck is likely as close to anarchy as I'll ever get
 Yeah
 I'm a rebel
