Tilting Speaker Amp
Tilting Speaker Amp
Have any of you seen the Kasha combo amps with the tilting speaker?
I was checking their Magnatone clones and saw this.
Pretty cool idea for a small combo and the ability to tilt the speaker up towards your ears.
Not sure if it is a patented idea or not.
[img:547:591]http://kashaamplifiers.com/images/Brick-Combo.jpg[/img]
http://kashaamplifiers.com/index.php?ma ... ucts_id=92
lord preset
Re: Tilting Speaker Amp
Post by lord preset »
Interesting but not all that desirable IMO. Increased weight reduced speaker cabinet volume, all to avoid tilting the whole amp to achieve the same result. Which is really not a problem. I use a Standback (http://www.standback.net) with my combos.
sixstringer
Post by sixstringer »
John Kasha is always coming up with innovative stuff. His tilting speaker amp design is a few years old but is pretty neat to see in action. There is a remote foot switch that controls the angle of the baffle, so you can "tune" it as you play.
If its just the baffle tilting you're going to get air leaking past it, or rattles.
If the tilting part is a separate sealed box you have a much smaller sealed volume than the size of the cabinet appears to be.
If its on a footswitch, then its got a motorized actuator.
Tiltback legs do the same thing cheaply and to my eye more eloquently.
I've also built amps with the baffle at fixed tilt.
Yeah, but that one has a Whizzer! :lol:
NickC
Post by NickC »
