Why not build an Express preamp? IIRC the SE Express has already been done and you. Look around for it.Meat&Beer wrote:...With a big fat preamp that has too many stages....
Goin' for gain, if I haven't been clear on that one.
IMO, they wouldn't have published it if they didn't mean for it to be used. They put it in the public domain knowing others might use it. There is nothing to feel bad about.I feel awful taking peoples hard work they've done, and cashing in...
OK, let's not get carried away.I love you guys.
+1 on using a 6V6. You might have enough for a 6L6, but I think it will be close. You are probably pushing too far for EL34, KT88, etc.
As has already been said, a SE amp is not very efficient. Pushing that PT to the limit may not be particularly wise.
Your question about using it just because you have it...well, in the end that's up to you, but it is as good a reason as any to build an amp. There is everything right about doing it and nothing wrong that I can see.
I don't know what sort of tone you are really looking for. You may want to rethink your power amp section. The tube I always think of when you need low current draw but have high plate voltage is the 6SN7. This is a dual triode that is good for about 5W in push pull and a single tube (two triodes) will want to see an OT primary of about 22K (though they are very forgiving). If you use 3 of them, you get to about 15W with an 6K to 8K OT very nicely. Don't look for power amp distortion. You'll need to get all your dirt from the preamp. You will get to experiment some with the PI, as well. I built one amp using 2x 6SN7 and used a concertina PI. The LTP might be too pushy for these triodes which is why I said you've got to do all the tone shaping in the preamp. I might look here for the OT20PP http://www.musicalpowersupplies.com/products/ though I suppose there will be lots of choices in this power range and primary impedance. Whether you do something like this depends on how big your sense of adventure is and be prepared to end up with something that may be different from what you are going for.
