The p782 is 800v ct @ 200 ma, 6.3v @ 5A. 5V recto tap for a Dumble-style "mega boost". The 800v rectified down should give me ≈565v max.
The A470 is self explanatory. 4.3k primary, 30 to 15 KHz at 70 watts. Also I found reading around TAG (the bold in the quote is my emphasis):
talbany wrote:I've used the real Dynaco A470's in several builds (mostly 34's Express) and are no doubt KILLER!! iron. ...Although they were designed for a pair of 34's or 6550/88's these transformers were 100% over spec and can easily handle 100 watts on a bad day..
A 470 weight pushing 10lbs
Any other insight or advice would be greatly appreciated!
