What to build next in the ODS-100 department ???
What to build next in the ODS-100 department ??? This will be the last ODS build.
So far #124 100 watt modified form, #124 100 watt original form, #183 100 watt modified,
Duane Allman 50 watt original design vintage transformers. ODS Black Flag 100 watt this is one of the best vintage Fane studio 12L in a combo. #4 SSS 100 watt, #5 SSS 150 watt, #7 SSS 150 watt.
The SSS is to dam heavy around 100 pounds to lug around but sounds great with 4 x 12 EV12L
I'm gravitating towards a #102 I have built one in the past but was not happy with the end result
I have the correct transformers for #102 now 690 volt / CT no load PT with a 4 ohm OPT it's huge.
I do this for fun and the SSS builds took the fun out of amp building for me 2400+ hours of study.
sifting through all the disinformation on the SSS 150. I'm not interested in a HRM or a Bluesmaster.
I have vintage Marshall's, Hi-Watts and Park Marshalls to fill that void.
Chime in what to build in the ODS 100 watt ?????
Best regards, Steve.
Re: What to build next in the ODS-100 department ???
Did you ever see the thread I posted on how to build this known serial number 100W ODS? I don't know if anyone else that posts here built it. Excitement over 102, 183 & SSS seems to have pushed that thread into obscurity. It is a HRM, but even if you have Marshalls, you might want to check it out. http://www.youtube.com/watch?v=78raAKXpZtI67plexi wrote: Chime in what to build in the ODS 100 watt ?????
"You feel like you're floating on a football field filled with marshmallows." -Dumble
Link to build info for that one on TAG?
Here is the thread: https://tubeamparchive.com/viewtopic.ph ... sc&start=0
ic-racer thank you for the reply. I'm not thrilled over #102 I spent one year on a #102 build
I just did not have any love for it so I gutted it. HRM would be a new build for me
I can just build a new preamp board to accommodate Johns HRM board
use the filament supply to power the 5v relays I have a filter board and a regulator board for it.
and use a 7 pin din for the foot switch. From what I gather the HRM is a high plate mid plate.
V-1 220k/150k V-2 180k/120k Is the HRM the combo that Eric Clapton is using now ???
One game changer is my filament supply is only 6 amps that would be cutting it close for EL34's
Steve.
Steve.
The 'real' amp that mine is based on has a sticker "TF130" on the power transformer. That may or may not have been underpowered for the EL34. I just went ahead and used a Magictone with 5.5A supply and have not had any issues.67plexi wrote: One game changer is my filament supply is only 6 amps that would be cutting it close for EL34's
Steve.
Made a new preamp board and the HRM is mounted
This is the dirt cheap build I decided to use parts I had in stock .
Working on the FET. I may order a Marstran JMP-100 C1998 OPT if I don't like the 4 ohm OPT.
I'm going to burn it in with cheap trash Russian EL-34 then install a Quad of NOS GEC KT77
dcribbs1412
Cool
Nice
so you doing 2 amps or just forgoing the HRM board?
Darin
Darin
You can say I'm building two amps .At the same time. As far as builds go this is #13 and #14
I have two more builds after this then I'm finished in the amp building department.
I thank TAG for all the vast wealth of information.
Steve.
Steve.
- David Root
I've always been curious about the 700V plate/350V screen model HAD built with Music Man iron and EL34s.
Years ago someone on TAG described it as having "mids you can stick your head into" and I always remembered that description!
DaveDavid Root wrote:I've always been curious about the 700V plate/350V screen model HAD built with Music Man iron and EL34s.
here is a quick clip of my Music Man. Apart from the throaty mids it also has this wooly kind of break up that is pretty cool..
http://www.youtube.com/watch?v=ycsYz5RLH34
Rat's Nest
dcribbs1412
Very cool clip Tony.talbany wrote:DaveDavid Root wrote:I've always been curious about the 700V plate/350V screen model HAD built with Music Man iron and EL34s.
Steve your looking close to power up.
Really nice combo of parts.
Darin
It's moving along FET is set ,the OD trigger is set to 24k. 32 wires to go then adjust the droping string.
