Solder Glue
Aurora
Re: Solder Glue
Post by Aurora »
The first connections of the long leads clearly goes through the holes in the lugs, and so does one end of the short parallell links. Although he would be better off wrapping a piece of wire around the lug where there was no room, he is esentially OK for such a short piece of wire.....
Not exactly MIL spec or space grade , but probably OK.....
Hollow tube type lugs don't give any anchoring than the solder, either, and there's plenty of those in MIL eqpt.
You'd be amazed of what one finds inside high grade and extremely expensive pieces of equipment......
overtone
Re: Solder Glue
Post by overtone »
No, I call that poke and hope.
Miles away rom MIL.
NickC
Re: Solder Glue
Post by NickC »
Aurora wrote:The first connections of the long leads clearly goes through the holes in the lugs, and so does one end of the short parallell links. Although he would be better off wrapping a piece of wire around the lug where there was no room, he is esentially OK for such a short piece of wire.....
I usually put at least a snug 45 degree bend in any wire terminating in a lug, and more often wrap wire around terminal/turret/lug at least half way.
A buddy of mine recently retired from a major defense contractor. He wired the large racks for radar systems. His work was constantly inspected to maintain discipline to due diligence and care.
Re: Solder Glue
This is where you strip one wire way longer. Attach the second wire to first wire wrapping it around and solder. Using the longer wire as the one that passes through the hole on the jack.
Or one through hole and other wrapped around spade.
The way this guy did it will work we know that but not good practice. :)
Aurora
Re: Solder Glue
Post by Aurora »
I usually don't see any point in nitpickin', but that's basically what I said... :)
OTOH - those 2" or so of wire, have so little mass, that he'll be OK, even if we both probably would do it differently........
Re: Solder Glue
Oh, this must be a video of one of my amps.
:oops:
Bob S
Re: Solder Glue
Post by Bob S »
OK - who drills the lug hole out bigger so that you can poke 2 wires thru ???
:oops:
Why Aye Man
Re: Solder Glue
I use 18 ga for the jumper then it fits in the hole.I don't see why that 2 inches of wire needs to be 16 ga.
Of course I'm not known for doing real smart things.
But I wouldn't do it like the guy in that video
Re: Solder Glue
I also like to tin the wire beforehand
Re: Solder Glue
martin manning wrote:I like this comment:
"thanks man i made a misstake as im new to amps and bought an epiphone head and tried to play through it then i found out i need a speaker cab... wtf"
BAWAHAWAHAWA!!
Wait, I did that before. :shock:
Not long enough to damage it though. :D
Re: Solder Glue
If speaker cabs with parallel jacks went to the ISS, they might be wired like this:
Re: Solder Glue
Your so smart. :)
