JazzGuitarGimp wrote:Unless I missed it, the guy in the video doesn't mention glue. Can't see it? You on an iPad?
He was treating solder like glue for those wire connections, none of which were mechanically coupled to the jacks; a couple of which were merely leaning against the connectors and held there by solder ..... like glue. Also note how the iron was used to melt the solder until it flowed onto the wires, rather than heating the connections and applying the solder to there rather than the iron. Terrible technique. A catastrophic breakdown waiting to happen.
Re: the other connectors
I don't think they're XLR, I think they're Speakon connectors.
NickC wrote:He was treating solder like glue for those wire connections, none of which were mechanically coupled to the jacks; a couple of which were merely leaning against the connectors and held there by solder ..... like glue. Also note how the iron was used to melt the solder until it flowed onto the wires, rather than heating the connections and applying the solder to there rather than the iron. Terrible technique. A catastrophic breakdown waiting to happen.
Can't see the video also but my imagination does pretty well here - holey smokes - this is a tutorial on how NOT to do it. One thing I learned early-on, also I'm sure all the rest of us good to excellent techs, is solder is NOT electrical "glue".
XLR on the back of my Vox AC50 looks a little crusty with age, but the pins still work fine, that's what counts. And that AC50 sounds mighty good.
