Tube amp has static noise (clip inside)
Lublin
Post by Lublin »
So I picked up a Mesa Boogie Bass 400+. It's a 12 6L6 and 4 12AX7 beast. It wasn't working but I got it really cheap so I took a gamble.
Brought it home and opened it up. Noticed one 6L6 was milky and had cracked glass. Went to pull it and it fell apart. Bingo - there's the issue. Replaced the 6L6 an its neighbor with a matching pair as well as the 8 amp slo blo fuse. Fired it up and it works. Lucky.
The only now is that there's a crackling sound when I play. I can actually stop playing and tap on ANYTHING within the chassis and the crackling happens. Below is a recorded sound of what I'm hearing.
Any guesses? Any help is super appreciated.
http://soundcloud.com/lublin-1/mesa-40/s-zeHNa
Re: Tube amp has static noise (clip inside)
Loose connection. Dirty tube pins, dirty pots, dirty effects loop jacks, etc. Give it a good cleaning and inspection.
TWELVE 6L6?!? Wow. Please post a photo of that transformer set. Amazing.
Never mind, plenty of good photos on Google:
http://www.gospel.bo.it/albums/userpics ... CT1013.JPG
What a beautiful layout for the power tubes!
Blackburn
Post by Blackburn »
Do the lights in your house dim when you flip the switch?? :lol:
That's disgusting.... For guitar anyway. For bass it's probably just right. It's gonna suck having to buy three matched quads when the time comes to replace all the tubes. :o
Lublin
Post by Lublin »
HAHA!
Going to re-tension all of the tube sockets and replace all of the preamp tubes. If the noise persists then I have to dig deeper.
I gotta tell ya - for bass, this amp is out of this world. The earth shaking tones this thing puts out are extraordinary.
I'm gonna cook dinner on it. Move over. :shock:
That's impressive, a dozen big bottle tubes. I had thought about an octet of 6AQ5's just because I have many of them, but this?
Lublin
Post by Lublin »
Replaced all preamp tubes
Cleaned tube sockets
Retentioned tube socket springs (took forever)
Still having the issue. I can tap on anything on the amp and get that static noise.
I'm thinking it may be a loose connection somewhere. Finding it is going to be a nightmare.
eddie25
Post by eddie25 »
Have you jumpered the effects loop yet?
Lublin wrote:Finding it is going to be a nightmare.
That what the Chinese invented the chop stick for.
+1 on the FX loop.
Lublin
Post by Lublin »
OK. I think I isolated one power tube socket as the source. When I push down firmly on the top of that one power tube the static scratchiness stops. As soon a I let go it starts up when I tap on anything. I checked underneath the socket and looked at all the solder joints and they look solid. Weird.
Lublin
Post by Lublin »
Fixed! Got fed up and jus replace the tube from the suspect socket and its mached neighbor. Scratchiness and static = gone and the amp is perfect. One of the pins on the tube must've been corroded or something. Wish I tried that a while ago. D'oh!!!
Whoa, what a beast! :shock:
Must be a small fortune to retube that beast.
Do you have to run it on a 20A breaker? :lol:
Jackie Treehorn
Post by Jackie Treehorn »
Nice amp. I would have guessed a leaky coupling cap based on that noise clip and the burned up tube.
That is a lot of 220uF filter caps.
Maintaining that amp sounds like a money pit.
But I'd bet it could drive a really loud subwoofer! :D
