Turrets
Turrets
In the past I have always used eyelets for my projects. I have decided that I like working with turrets for certain applications. Where is the best place (ie: Cheapest) to buy double turrets for 1/8" circuit board material.
- JazzGuitarGimp
Re: Turrets
CE Distribution.jon wrote:In the past I have always used eyelets for my projects. I have decided that I like working with turrets for certain applications. Where is the best place (ie: Cheapest) to buy double turrets for 1/8" circuit board material.
Re: Turrets
I get the double turrets from Ken Watts. Click on "Turrets" in the left-hand category list:
http://www.turretboards.com/
He also has the Staking Tools in the selection immediately under "Turrets".
Re: Turrets
I guess the thing about turrets is you can make a mechinical connection by wrapping leads/wires around the turrets before soldering.But most everyone I see just stuffs the leads down in the hole.
Or are we talking about uncontrollable cursing?
Re: Turrets
Works both ways (cursing notwithstanding). Wrapping leads a half turn around the turret, and then solder, is good. The double turrets can easily hold three components: two wrapped around the posts (one on the high part, another underneath) and a third with leads dropped into the holes. Flexible and easy to work with. After using them in several builds now, I like 'em better than eyelets.cbass wrote:I guess the thing about turrets is you can make a mechinical connection by wrapping leads/wires around the turrets before soldering.But most everyone I see just stuffs the leads down in the hole.
Re: Turrets
I like the slotted ones.
Re: Turrets
ExactlyNickC wrote:Works both ways (cursing notwithstanding). Wrapping leads a half turn around the turret, and then solder, is good. The double turrets can easily hold three components: two wrapped around the posts (one on the high part, another underneath) and a third with leads dropped into the holes. Flexible and easy to work with. After using them in several builds now, I like 'em better than eyelets.cbass wrote:I guess the thing about turrets is you can make a mechinical connection by wrapping leads/wires around the turrets before soldering.But most everyone I see just stuffs the leads down in the hole.
Re: Turrets
But....don't loose sight of the eyelets (pun..intended!).
There are many places on a board where they are preferred over turrets (i.e. where you have more than ~3 components coming together in one place).
I, generally, prefer turrets. However, I have recently started using both and have been kicking myself for not doing that a lot earlier.
Good luck,
Dave O.
Good luck,
Dave O.
Re: Turrets
I like turrets if I know what I'm building Alot of times I make it up as I go along.Eyelets are much easier for swapping parts.
- Milkmansound
Re: Turrets
I use turrets from Watts
I will put a wire down into the hole, but before I do I hit the top of the turret with some fine grit sandpaper and really make sure the solder joint is shiny and perfect. Sometimes the turrets have a layer of oxidation on top.
- randalp3000
Re: Turrets
If you have a CE account the 3mm are only $1.40 per 10 pack. I think you can get 4 small leads in these if your careful. Some times I'll drill the tops out just a bit also.
I love Watts too but at $27 for a 100 I'll shop CE.
EtherealWidow
Re: Turrets
I'm using a terminal board like this on a build right now. https://taweber.powweb.com/store/longboard.jpg
Not too bad, although the filter caps don't fit on the two inner terminals. Other than that, I haven't run into any real problems...yet. Still just mounting components, though.
- LeftyStrat
Re: Turrets
I like turrets to wrap parts around, but also because under-board wires can come up through the turrent center post and wrap around the post. I'm always paranoid about under-board wiring falling out during a parts swap with eyelets.
Re: Turrets
I was using boards like the one from Weber and they are just OK. I think they are not as nice as a real turret board. (Also, you can buy the same board on eBait direct from China for half the price, postage included.)EtherealWidow wrote:I'm using a terminal board like this on a build right now. https://taweber.powweb.com/store/longboard.jpg
I found for about $10 you can buy a real generic turret board: http://www.tubesandmore.com/products/P-HTUR-60 I used one of these in my last build and liked it a lot better and it is worth the extra few dollars. Because it has lots of unused holes, I was able to add a few turrets in key locations to make it more suitable for my needs. Of course, YMMV.
One thing I don't want to do is drill and stake my own board. The fiberglass is supposed to be carcinogenic if you breathe it in, and I don't have the proper dust collection system to be working with it. Once in a while I drill an extra hole keeping the drill at slow speed to control the flying dust. It is wise to wear a proper mask when drilling.
- randalp3000
Re: Turrets
I have a few of those and they are quite nice. They have the 2mm and 3mm turrets as well http://www.tubesandmore.com/products/S-HTUR-BPhil_S wrote:I was using boards like the one from Weber and they are just OK. I think they are not as nice as a real turret board. (Also, you can buy the same board on eBait direct from China for half the price, postage included.)EtherealWidow wrote:I'm using a terminal board like this on a build right now. https://taweber.powweb.com/store/longboard.jpg
and blank boards in 2 and 3mm http://www.tubesandmore.com/products/P-HTUR-C
don't waste your time on the cheap boards http://www.tubesandmore.com/products/P-HTUR-A not very good
