M Fowler wrote:Nice build.  I used to collect as many of those amps as I could find and convert them to guitar amps adding 1/4 jacks.  Mine worked as is so I didn't need to rebuild them.
Fun projects.
Thanks Mark! I pulled this one out of a barn, was a literal rat's nest, lol. It had an octal in V1, and I kept it for my first go around, but I couldn't get rid of a nasty oscillation no matter what I tried, until I put a nine pin socket in it's place.
I've got a question for y'all...I built this basically from what I had laying around..the OT came out of a Bassman 10 (2X6L6 output section). Figured the bigger iron would sound good. The amp does sound ok, but I was expecting it to break up sooner. Here's my voltages, using a 5Y3 rectifier:
B+ 451
B+A 446
B+B 325
V1 1 224, 6 211
V2 1 273, 6 257
449V on output tube plates, 444 on pins 4 ( Currently JJ 6V6's)
I've added a bias trimmer pot to make things easier when trying different tubes.
So it's looking like I need to knock down some B+, eh? Any thoughts on which part of the string to mess with? I've heard of folks keeping the PI a bit high In these amps for a bit more output while keeping some grind. Any thoughts?
Thanks in advance as always
Oh, and the bias tremolo is fracking amazing!
