NEW CHASSIS RUN!!
Funkalicousgroove
Re: NEW CHASSIS RUN!!
Post by Funkalicousgroove »
The PT has the same centers as a Twin Reverb/Showman
3 3/4" x 3" I believe
toneman
Post by toneman »
I'll take 1 chassis with the Pre-done PCB's .Thanks again Mr.Funkalicousgroove
rhubarb9999
Post by rhubarb9999 »
I am in for a set ... with all the PCBs
What is the best source for the trannys?
Funkalicousgroove
You can get them from Mercury Magnetics, Mojotone, Hoffman, Heyboer, Pacific, etc.
I have some custom Heyboer PT's in production they will have an extra 6.3v tap for relays, and the main filament tap will be 7A to easily support EL34's.
tonejunkie
Post by tonejunkie »
Dang it Funk stop having custom stuff made that I want! :evil: Will you make some of those tranformers for others?
TJ
Ok, thanks for all your hard work. Your the man
roadkingbluzs
Post by roadkingbluzs »
Still in! Please keep us posted. Looking forward to this build, have better confidence since D-Lite build. Thanks Rocco, Normster and friends !! I am sure this will be just as rewarding experience.
Funkalicousgroove
TJ,
I can add one to my order for you, but I'd need to know ASAP. They will be $90 or so plus s&H to me, then to you. weight is 12lbs.
What state are you in? it may be more effective for you to order it direct-
Funkalicousgroove
OK, going to the metal shop on monday, we are going to make a couple teeny "Improvements" to the previous chassis and then they are in production. The goal right now is to have painted chassis within 30-45 days.
I will have 20 sets available this go round, and If that's not enough my sheet metal guy plans to be able to make more soon after.
odourboy
Post by odourboy »
I PMed you the other day that I was in for a one with a full set of PCBs, but since I'm not sure where you're keeping the master list, I'll confirm on the main thread.
Any chance of getting board standoffs and any other hard to find stuff like indicator lights or power switches (not sure how 'standard' some of these bits and pieces are.)
Cheers!
Brian
v00d00blues79
Post by v00d00blues79 »
Funk,
Let me know if there's still room on the list for a set.
Thanks,
Andy
Kersey
Chassis and board sets
Post by Kersey »
I'm in for at least one set with PCBs, maybe 2 if there is an extra.
Please let me know the payment details.
Thanks,
KK
Kersey
Post by Kersey »
Thanks,
KK
Funkalicousgroove
As it turns out, My sheet metal guy has an extra 18 blanks "Just in case"
so I'll have more than enough for everybody it looks like!!
Mastervolume
Post by Mastervolume »
I'm in for the chassis and the boards!
should there be sparks?
roadkingbluzs
Funkalicousgroove wrote:You can get them from Mercury Magnetics, Mojotone, Hoffman, Heyboer, Pacific, etc.
Will check if PT I intend to use will support build , if not I may flip for one of your Heyboer's.
