Dream amp?
				EtherealWidow
Dream amp?
Alright. Didn't find another thread like this, but it's pretty self-explanatory. Post your dream amp topology no matter how expensive, complicated, or inefficient they may be. Reeltarded, feel free to get... retarded.
Here it goes: V1 & V2 6SL7 cascode. V3 12AX7 gain stage with a big Ra for more voltage swing into V4, a DC cathode follower. I don't even know what kind of tonestack. Plexi, AC30, 5F6A, whatever... then parallel SE EL34 and 6L6. Tube or SS rectified. Doesn't matter.
Re: Dream amp?
Three 12ax7 and then a pair of EL34--all Mullards.
						Re: Dream amp?
Multiple voicing on input (resistive load) for active electronics.  3 selectable gain stages that can be inserted as desired or fully true bypassed.  Off two 6k11 tubes (Ampeg reverb tube). It's three 1/2 sections of a 12ax7.   Same tubs again for the EQ. A gain bypassable. Passive active buffered fx loop transformer isolated from input DI with independent tube driver.  Octal tube phase inverter. Master and presence controls. 150 watts output with 2,4,8,16 taps 5k impedance.  4 el84 with selectable snubbers, 4 el34.  Outputs tubes selectable between pairs quads and blending.  Two tube rectifiers selectable to solid state.  Optional insert bus for external add on tube driven reverb and a foot switch that selects input gain stages and a resistive boost for stepping out for solos, fx loop in/out. With add on port for reverb control.
I want 700v from the PT and a roadie to move it.
My Daughter Build Stone Henge
						- Reeltarded
Re: Dream amp?
Get out of my dreams! (and into my amp) lolJana wrote:Three 12ax7 and then a pair of EL34--all Mullards.
				EtherealWidow
Re: Dream amp?
Oh wow. I'm glad I don't know more about amps, otherwise I might be inclined to dream up something that ridiculous.selloutrr wrote:Multiple voicing on input (resistive load) for active electronics. 3 selectable gain stages that can be inserted as desired or fully true bypassed. Off two 6k11 tubes (Ampeg reverb tube). It's three 1/2 sections of a 12ax7. Same tubs again for the EQ. A gain bypassable. Passive active buffered fx loop transformer isolated from input DI with independent tube driver. Octal tube phase inverter. Master and presence controls. 150 watts output with 2,4,8,16 taps 5k impedance. 4 el84 with selectable snubbers, 4 el34. Outputs tubes selectable between pairs quads and blending. Two tube rectifiers selectable to solid state. Optional insert bus for external add on tube driven reverb and a foot switch that selects input gain stages and a resistive boost for stepping out for solos, fx loop in/out. With add on port for reverb control.
Re: Dream amp?
MMmmmm XF2s....
Re: Dream amp?
I'm thinkin one with a beer tap and some sort of hookah that never runs out and a knob that slows time down.So I can smoke my hookah drink beer and play guitar all day.
						Re: Dream amp?
Quite some years ago, I was on a fairly large science prosject.
The main control console, operated by two visiting engineers, had this funny looking handle and a huge switch in the top section, - labeled Pre and Post Op's.....
After the main operation was done, the switch was turned to 'Post Op', and the handle, which proved to be a spout, poured a well known dring in these areas, known as 'Mountain Brook' - contains a fair amount of aquavite.....
How about that for an extra function? Scotch - anyone ?
						- VacuumVoodoo
Re: Dream amp?
1000W SE using one big ass water cooled triode and 100W HiWatt with a Supafuzz in front to drive the whole thing + 4x4x12 quad stack.
And Adrian Gurvitz plugged into it playing Race with the Devil 24/7......
Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
Zagray!-review
				Kinkless Tetrode 66
Re: Dream amp?
My dream amp is one, where there is an infinite volume and infinite gain knob...  and a selector for any Fender amp ever made, till present time,with an "era-blender" switch.  I mean all you would need - thousands of tone stacks, about a dozen glass bottles, various speaker configurations, a variac, and some tweed!
				Kinkless Tetrode 66
Re: Dream amp?
Also would not mind having the "cbass" signature amp...
						Re: Dream amp?
You need to do a version of this to "no money down";selloutrr wrote:Multiple voicing on input (resistive load) for active electronics. 3 selectable gain stages that can be inserted as desired or fully true bypassed. Off two 6k11 tubes (Ampeg reverb tube). It's three 1/2 sections of a 12ax7. Same tubs again for the EQ. A gain bypassable. Passive active buffered fx loop transformer isolated from input DI with independent tube driver. Octal tube phase inverter. Master and presence controls. 150 watts output with 2,4,8,16 taps 5k impedance. 4 el84 with selectable snubbers, 4 el34. Outputs tubes selectable between pairs quads and blending. Two tube rectifiers selectable to solid state. Optional insert bus for external add on tube driven reverb and a foot switch that selects input gain stages and a resistive boost for stepping out for solos, fx loop in/out. With add on port for reverb control.
http://www.youtube.com/watch?v=Gp-3Ra5BQ5g
Re: Dream amp?
Man, I haven't listened to that tune in a while! I think I'll give the album a listen today. Can't even remember any of their other songs.VacuumVoodoo wrote:1000W SE using one big ass water cooled triode and 100W HiWatt with a Supafuzz in front to drive the whole thing + 4x4x12 quad stack.
- randalp3000
Re: Dream amp?
2 channels,
EF86 brilliant and
12AX7 parallel, no tone stacks, 12AX7 PI to El84's cathode bias no NFB
But I want 100 clean watts and weighs 20 lbs
						EF86 brilliant and
Re: Dream amp?
No hum and it needs to sound good with any type of pickups or cab combination and at any volume.
