Got it.pdf64 wrote: Jaz, I was suggesting eliminating the current sharing between the cathodes, change to independant biasing / bypassing.
Pete
Thanks,
Jaz
Pete
Without the positive feedback into right hand triode grid combined with low value shared cathode resistorpdf64 wrote: Alex, apologies but I can't see the positive feedback that you mention as being key to its operation?
Pete
Nicejazbo8 wrote:https://dl.dropboxusercontent.com/u/132 ... erters.pdf
Finally had sometime to run some sims... Without the positive feedback, the differential PI is indeed very un-balanced (as shown on the upper right chart).
The above sims show the results for perfectly matched sides, but when the two sides are not matched - with the differential pair + CCS tail configuration (and the cathodyne since only one side is used), the outputs remain pretty much in balance. However, with the proposed circuit, the outputs will be un-balanced unless further adjustments are made to the output load and/or the feedback ratio. Is that right?
Jaz
