Well, I must honestly say I don't know. I never try to resurrect dead components or that have drifted beyond spec limits. They all go to the nearest recycling plant.David Root wrote:Aleks, I know it sounds wrong, but I have dried out over a hundred old orange drops and chocodrops that had spent 30-40 years in non-A/C storage in Houston, a very humid climate, and that gets them back in spec about 90% of the time. It takes about 72 hours at 225 deg F in a convection oven to do it.
I measured them before and after drying them out and there is no doubt that the values do come down quite dramatically in most cases.
If it's not humidity what else can it be?
I might attempt to bake and re-impregnate a leaky cardboard from a water damaged old Fender, but that's really as far as I will go. A new eyelet board is cheaper and faster to install in most cases.
Most film caps are supposed to be hermetically sealed, if they sucked up some humidity it means the sealing has become compromised. I suspect that even if You bake them dry as bone in the desert, they'll suck up humidity again sooner or later.
We'll see what some capacitor data mining will produce.
