talbany wrote:should we go ahead and change the layout
Tony, IMO it depends:
1st question: What's the correct value of the two TEAPO capacitors visible on the pictures of #0124 posted by Gil Ayan? As I posted in one of my previous posts in this thread I don't know the value of these two TEAPO capacitors in #0124 because the value of these capacitors isn't visible on the pictures posted by Gil Ayan - at least not for me.
2nd question: Are these two TEAPO capacitors a part of the skyline update of #0124 or not? AFAIK no one here knows if these two TEAPO capacitors were fitted when #0124 was updated to skyline specs or when it was originally built with a "classic" tone stack. IMO the only "proof" would be some residual traces of the original black goop on the two TEAPO capacitors or some pictures taken before the update etc.
So IMO - if no one here knows the answers - some kind of written comment in the "124 Low Plate Classic" layout could perhaps explain that the value "10uF" is only based on the handdrawn schematic and isn't based on the pictures.
And in addition a second comment could perhaps explain that it's only an assumption that these two TEAPO capacitors are a part of the "classic" version of #0124 and not a part of the "skyline" update.
And a third comment could perhaps explain that if these two TEAPO capacitors aren't a part of the skyline update but are a part of the original "classic" version, #0124 would be the only "classic" ODS with a value of 10uF known to the members here and that in all the other ODS amps with a "classic" tone stack and a "standard" OD-circuit known to the members here these two capacitors have different values. AFAIR 4.7uF (low plate classic) and 5uF (high plate classic) are the values known to the members here. Or do I remember wrong?
What do you all think about this?
Max
