Soldering Temp
ronman
Soldering Temp
Post by ronman »
What temperature do you guys solder at. I recently bought a used soldering station that has a temperature readout and was wondering.
NickC
Re: Soldering Temp
Post by NickC »
My station is set at 650 degrees F.
JazzGuitarGimp
Re: Soldering Temp
Post by JazzGuitarGimp »
I run mine at 700F most of the time. I'll push it up to as much as 800F if I am soldering something large and having a difficult time with it.
Gaz
Re: Soldering Temp
Post by Gaz »
699F
selloutrr
Re: Soldering Temp
Post by selloutrr »
740F with a precision fine tip.
960F on the rework station
My Daughter Build Stone Henge
vibratoking
Re: Soldering Temp
Post by vibratoking »
As low as I can to comfortably get the job done...650 for me with the solder I use. If I have to push up the temp I MIGHT, but I also am aware that I can do damage and that I am probably using the wrong iron or tip for the job at that point.
tribi9
Re: Soldering Temp
Post by tribi9 »
800F
Re: Soldering Temp
Are we talking lead based solder?
60/40 or 63/37?
I use the eutectic 63/37 @ around 700F.
Cygnus X1
Re: Soldering Temp
Post by Cygnus X1 »
737.25
Hakko FX-888 with a precision tip.
60/40 rat shack solder.
rp
Re: Soldering Temp
Post by rp »
800F - hot, clean, fast,
My Weller is the bottom line w/o display but it's always maxed. I clean the tip (ETA?) continuously, I move fast. I even do circuit boards like this unless I hit a snag then I might simmer down. Always w/ Kester 44 (.05 for tubes amps) I usually use heat sink clips too. Radio Shack has these small fake copper alligators that are very small and have non serrated jaws.
overtone
Re: Soldering Temp
Post by overtone »
666 mostly
752 for rework
drop the station down to 300 while picking my nose
Actually, for the solder I use at the moment, that 666 is rather hot:
"Future" cored, no clean, 63/37 tin-lead from Warton Metals in the UK
and WBT-0840 audio fool solder from Germany for anything stubborn or pretty. I'm using the WBT more and more now in fact. Wonderful to use.
Best, tony
Re: Soldering Temp
I looked up the WBT - 0840.
4% silver but it has a pretty low melting point @ 356F
Not sure I would use that on a tube amp but I'm not sure how hot things get in there.
overtone
Re: Soldering Temp
Post by overtone »
Tom I had never really thought about that and realize now that I do not even know how hot in °F or °C the leads of some of the resistors may get. I would be surprised if they got that hot, but stand to be corrected.
I really, really did not want to like the WBT solder but it does so well where others just refuse to work.
Best, tony
