Resistors are linear. However, a GZ34 voltge drop curves are available. I just don't think it's all that important to sweat about 5-10 volts variance on the B+, depending on what type of rectifier you have in there. If you look at the GZ34 amp/voltage curves, they look fairly linear from 100-250 mA.
I swapped the WZ34 copper cap for a GZ34 in one of my amps, and the cranked output rose from 50 watts to nearly 70; wasn't expecting that (as the static B+ was pretty close), it killed my favourite speaker (Weber 12F150 50 watt) in short order, which I been happily cranking for nearly 2 years.
The only sonic difference you will get with the progression to solid state diodes is the elimination of voltage sag on the B+
Just to quality that, no rectifier sag, most Si rectified B+ supplies will sag maybe 10% when cranked, due to copper etc transformer losses and increased ripple from draining the reservoir cap.
If your amp is a single eneded class A, then the current doesn't increase at high volume, and you don't get any additional voltage sag, so it's not influenced by the type of rectifier
That's the case with hifi, but most classic guitar amps are used overdriven, to some degree at least (my Marshall Superlead bright channel couldn't be played clean with a Les Paul etc); outside the linear range amp class doesn't really apply.
My experience is that class A amp's power supplies usually sag when overdriven.
Pete
