SSS #2 Started
FuzzFaceBuilder
Re: SSS #2 Started
Post by FuzzFaceBuilder »
dreric wrote:
FuzzFaceBuilder wrote:Those are pics of the "Alligator Pentode" amp, not an SSS.
Count the knobs on the "top view" and compare to the photos below.
Thanks, any history?
Eric
Here you go!
https://tubeamparchive.com/viewtopic.ph ... +alligator
dreric
Re: SSS #2 Started
Post by dreric »
Here's some progress:
1. Chassis punched and drilled.
2. Mounts in.
3. Transformer placement.
4. Transformers.
Eric
dreric
Re: SSS #2 Started
Post by dreric »
and............
5. Main board detail.
6. Reverb detail.
7. PI Detail.
8-9. Overviews
Next, going to the mom & pop to see if they have and huge metal film 100K and NOS inductors!
Thanks for watching the progress, if you see error or over sites please advise.
Eric
grtamp
Re: SSS #2 Started
Post by grtamp »
that big OT trafo!!!
dreric
Re: SSS #2 Started
Post by dreric »
grtamp wrote:that big OT trafo!!!
thank you
ToneMerc
Re: SSS #2 Started
Post by ToneMerc »
dreric wrote:and............
6. Reverb detail.
7. PI Detail.
8-9. Overviews
Eric
Looking good Eric
Mike
groovtubin
Re: SSS #2 Started
Post by groovtubin »
dreric wrote:Here's some progress:
2. Mounts in.
4. Transformers.
Eric
Is that a Hammond output from a Traynor voicemaster> Looks just like it, seriously GREAT trannies, built my first dumble conversion on a voicemaster and sold it! It can DEF handle 6550`s!!
have fun!
jim
AtomCap
Re: SSS #2 Started
Post by AtomCap »
better use some split lock washers on the pre-amp tube sockets, or lock-tite! lots of little things in there to rattle around (sry if overstating obvious!!!)
dreric
Re: SSS #2 Started
Post by dreric »
[/quote]Is that a Hammond output from a Traynor voicemaster> Looks just like it, seriously GREAT trannies, built my first dumble conversion on a voicemaster and sold it! It can DEF handle 6550`s!!
have fun!
jim[/quote]
It's a Hammond 1650R. Big but only rated for 100 watts. It's an ultra linear but I was planing to tie off the taps and just use the secondary. I got it for a ODS build but it's too big, mounts too close to the edge of the chassis on the CE chassis to fit into a cabinet.
I'm not extactly sure how to hook this on up, so feel free to look at the schematic and advise.
SSS #2 is reported to run twin iron with 6L6 and all 12AX7 so I was going to stick with that plan.
Eric
groovtubin
Re: SSS #2 Started
have fun!
jim[/quote]
Eric[/quote]ERic, i`m running a fender 75 UL w/HRM circuit, and it KILLZZZ..i`d try both ways man!
jim
dreric
Re: SSS #2 Started
Post by dreric »
Chassis work done!
dreric
Re: SSS #2 Started
Post by dreric »
I changed the transformer selection. I was going to go with a Hammond set but the OT didn't fit the chassis, too big. So I went with a New sensor (mag components) PT, Choke and a NOS Fender Bassman 100 OT. Reverb is a old mojo thing. The New Sensor PT is rated a bit higher than the Hammond of standard twin (?).
1. PT specs.
2. Final placements.
3. Pilot lamp and heater.
4. Heaters.
5. Heaters.
dreric
Re: SSS #2 Started
Post by dreric »
More:
6. Heaters.
7. Back of Bias / rect board.
8. Bias / Rect placed.
Testing next, then PS filter board!
Hope you guys are enjoying the progress, happy holidays!
Eric
CHIP
Re: SSS #2 Started
Post by CHIP »
Looking real good Eric.
grtamp
Re: SSS #2 Started
Post by grtamp »
Hi , are you sure to use red/blu wire for bias?
