Volume pot open
tribi9
Volume pot open
Post by tribi9 »
The volume pot on my 5X3 is acting weird. It worked fine since i last messed with the amp about 2 weeks ago.
The pot is not turning the volume down. So at any point in the rotation thw volume is the same. At first i thought it was a grounding issue so i touched up the terminal joint that joined the pot terminal onto itself. I tried it and it worked fine for a couple of minutes but then it started doing it again, so then i ran a wire from the ground terminal on the pot to my common ground bypassing the casing of the pot. It worked again, this time for a few hours but then it started happening again. Tried a different pot same thing.
What do you guys think it could be?
Cheers and thx for your time. :)
Re: Volume pot open
I would guess that the wiper is intermittent.
Time for a new pot.
tribi9
Re: Volume pot open
Post by tribi9 »
I did try a different used pot, could it be my luck that both of them are bad?
ChrisM
Re: Volume pot open
Post by ChrisM »
Could also be a bad ground (loose) or broken/intermittent wire.
tribi9
Re: Volume pot open
Post by tribi9 »
Yeah, i think it was a ground issue. Used the bigger iron to put a piece of wire between the terminal and the casing then ran a wire to a common ground. Seems ok, hopefully this time for good.
Thx so much for the input.
tribi9
Re: Volume pot open
Post by tribi9 »
I guess i had two bad CTS pots from the same batch. I replaced with a CTS from mojo.. i had kicking around and the issue is gone.
