Hi,
My transformer supplier went dark.
How do you size up the Output transformer?
I need to find a new supplier.
Power section:
2 6SN7GTB's/ 4 6SN7GTB's.
4, 8, 16 ohm taps.
I assume you need to calculate total current draw and apply a safety factor.
I am sure there are more specification to qualify.
What are those?
Note: I have qty 1 output transformer/ and 1 power transformer from my previous supplier.
Regards,
Decko
Sizing an Output Transformer
Re: Sizing an Output Transformer
For the same results/product send him the old iron and let him reverse engineer them. Give him as much info on them as you can.
Yes call Heyboer but they may not divulge the specs of a custom transformer due to confidentiality.
Can't you use an off the shelf OT?
Just find a similar amp and use those specs.
You can copy core size from the existing one. Primary impedance and max current come from datasheet examples or load lines. But a pair of 6SN7s in push pull is often sized with a 20k OT rated for 2W or more. A quad needs 10k at 4W. Does the existing one have taps for the pair/quad or do you mismatch the output load? I think I remember MPS has a 20k 2W OT. But a 4W one is pretty custom. Although a 5W line PA transformer would work alright.
