Hi , I'm looking for a TF-130 ,I found two sites where sell this trafo, but with different price!
http://shop.magicparts.com/TF130
http://www.vibroworld.com/parts/tech5.html
can anyone tell me if these transformers are the same or different?
Manufactured from different factories?
Transformer TF-130
Re: Transformer TF-130
Note that Vibroworld has been closed since 2008 > http://www.vibroworld.com/index.shtml
The TF-130 designation is Magic Parts internal product code for a twin PT. Vibroworld used to carry MP transformers hence the code is the same.
I call MP last year when I was doing a 183 build, at that time their current manufacture was Magnetic Components.
There are a few documented Dumbles out there with MP TF-130, (#183). To my knowledge none of these uses the currently available Magnetic Component transformers.
I forget the name of the manufacturer that Magic Parts used to use, (maybe TI Transformer Industries) if you search 183 + Transformer you'll find it or maybe someone remembers the company. Regardless, they are not available.
Eric
Eric
FuzzFaceBuilder
If I recall, the TF-130 was made by Pacific. I think.
May be, Transformer Manufacturers Incorporated (TMI): www.tmitransformers.com/ ?
That's them!EaNot wrote:May be, Transformer Manufacturers Incorporated (TMI): www.tmitransformers.com/ ?
Eric
thanks all ,... does anyone have the wiring specifications of the TF-130 and TF-135?
