Quick video of my buddy noodling on the amp with clip leads hanging out all over. Some dropping resistors and coupling caps hanging out. I think I am going to keep these values and install them finally. Clean, 2 different OD's. Dlator built in. 6L6 50w +-. Built with info from the Amp Garage site as well as info I picked up on my own from other sources. Chassis is from my own line of amps. A little cramped but it works and sounds excellent. IMHO!
http://www.youtube.com/watch?v=Yjqy9NcW ... e=youtu.be
													Bluesmaster inspired prototype
						Re: Bluesmaster inspired prototype
I would be interested in whatever you are comfortable sharing about the two different OD's.Clean, 2 different OD's
Is it one OD channel in series into another?
"psuedo channel switching" using dual pots on trim, drive & level?
OR two totally different OD tubes & channels? (ex. a pentode on one channel and a 12A_7 triode on a different channel)
or something different altogether?
With respect, 10thtx
Nice amp cradle!
Whoa! Six relays?
I didn't realize you were a pro builder.
									Whoa! Six relays?
Thanks for the compliment.Structo wrote:Nice amp cradle!![]()
Whoa! Six relays?
Maybe 7 relays if I decide to put the effects loop on/off on a relay instead of a dpdt switch, but then it bumps the footswitch to 4 position instead of three.
Actually the amp cradle is a Weber that I modified.
JK
