toggle switches keep breaking
My buddy has  Fuchs Mod amp (Deluxe reverb was its original incarnation). He keeps breaking-off the toggles from the toggle swicthes (rock/jazz, mid, brite). Not the amps fault...IN any case, Does anyone know of some mini toggle switches with very very short toggles? Perhaps a short toggle would be less susceptible to being snapped-off
Much obliged,
P.
						Much obliged,
P.
Re: toggle switches keep breaking
I use these on the rear chassis of my D Builds and loops.pula58 wrote:My buddy has Fuchs Mod amp (Deluxe reverb was its original incarnation). He keeps breaking-off the toggles from the toggle swicthes (rock/jazz, mid, brite). Not the amps fault...IN any case, Does anyone know of some mini toggle switches with very very short toggles? Perhaps a short toggle would be less susceptible to being snapped-off
Much obliged,
P.
http://www.tubedepot.com/p-108-mini-2.html
TM
Man, that guy must really man handle those toggle bats to snap them off.
The worse problem I have is melting them when soldering to them.
I used the same ones on my recent build, But got them at mouser for a small savings.ToneMerc wrote: I use these on the rear chassis of my D Builds and loops.
TM
http://www.mouser.com/Search/ProductDet ... B3M1QE-EVX
Data Sheet: http://www.mouser.com/catalog/specsheets/MS-100755.pdf
~Chris
I have broke one before on a Rocket build I just figured it was a cheap bad switch
Steve at Apexjr.com stocks those mini switches too.
I know it's heresy, but maybe it's time to consider changing to a rocker type switch, where nothing sticks out!
Or old fashion Fender slider type.
EwwwwM Fowler wrote:Or old fashion Fender slider type.
I had a toggle on the back of an amp head that kept getting broken in transport.Does anyone know of some mini toggle switches with very very short toggles
I took a dremel tool cutting wheel and just shortened the toggle . Worked fine after that with no issues.
With respect, 10thtx
The amp is a Fuch's modded Fender Deluxe what better then to use Fender slider switches, problem solved.Phil_S wrote:EwwwwM Fowler wrote:Or old fashion Fender slider type.
Now that you put it in context, I can see doing this. It's just that the sliders have such a cheezy feel to them.M Fowler wrote:The amp is a Fuch's modded Fender Deluxe what better then to use Fender slider switches, problem solved.
Phil_S wrote:Now that you put it in context, I can see doing this. It's just that the sliders have such a cheezy feel to them.M Fowler wrote:The amp is a Fuch's modded Fender Deluxe what better then to use Fender slider switches, problem solved.
 You calling me a Cheezball Phil!
  You calling me a Cheezball Phil!   I actually like those old switches mostly because they are much higher quality and easy to solder to.  They come in a variety of types DPDT, SPST, etc.  Not as convenient as flipping a toggle switch on the fly but will not break off mid show.
   I actually like those old switches mostly because they are much higher quality and easy to solder to.  They come in a variety of types DPDT, SPST, etc.  Not as convenient as flipping a toggle switch on the fly but will not break off mid show.Mark
Is there a source for new Fender style slider switches with other varients (like DPDT for example) ?M Fowler wrote:Phil_S wrote:Now that you put it in context, I can see doing this. It's just that the sliders have such a cheezy feel to them.M Fowler wrote:The amp is a Fuch's modded Fender Deluxe what better then to use Fender slider switches, problem solved.
MarkYou calling me a Cheezball Phil!
Apexjr has the SPST fender slider switch n stock.
