Help needed with dropping string
				Ed de Jager
Re: Help needed with dropping string
Thanks,i will have to buy a few 3 wattrs then.
I have changed the 10K for a 22K as a few of you said.
Here`s the new voltages:
After the 500 Ohm:405V.
After 1K:401V.
After 22K:334V.
After 2.2K:321V.
V3-1:310V.
V3-1:276.7V.
V2-1:209,2V.
V2-6:213.6V.
V1-1:208.3V.
V1-6:208V.
I had a few minutes to play the amp and it already is a completely different amp!Clean was great already but the distortion chanel is coming to life now.I already like it a lot more!
Even my kids said they liked the sound while normally they just ask me to turn the volume down.
As i said i will buy a few 3 watters tomorrow;a 150K,220K and a 470K?
Any more suggestions would be appreciated as i have to drive quite a bit to buy them:-)
One more question:the huge difference in voltage at pins 1and 6 of the PI is that normal?I measured twice but didn`t think about chaging tubes
After 1K:401V.
After 22K:334V.
After 2.2K:321V.
V3-1:310V.
V3-1:276.7V.
V2-1:209,2V.
V2-6:213.6V.
V1-1:208.3V.
V1-6:208V.
They look like 2watt ABs.Ed de Jager wrote:I was talking about these resistors.Anyone familiar with them?
Sorry for the bad quality of the picture
Ed
2watt = 18mm x 8mm
1watt= 15mm x 6mm
.5watt= 10mm x 3mm
				Ed de Jager
Thanks but unfortunately they are 15x6m.
Can i use them though(since we`re not using math)?
I can`t get values above 22k in 3 watt over here.
Ed
Ed
Seen plenty of 1 watters in Fenders and other amps over the years that are still going  strong 30 years down the track (also the opposite ). Always a gamble with CCs. If you have the room you can use a pair in parallel or series ( if  you have the right values of course) as subs till you get new ones.
				Ed de Jager
What would be the worst case scenario;the 1 watter burning out or could it give more trouble then that?
Thanks in advance,Ed
- Funkalicousgroove
CC's start on fire when they burn up........that's why they're no longer made!
				Ed de Jager
So the worst case scenario would be me being homeless.Hmm.
The good news is that i`ve found 4 220K 2 watters,gonna try em out tomorrow and let you all know.
Ed
Ed
				Ed de Jager
Hi again:-)Tried out the aforementioned resistors.
The(what i thought was)220K gave 104 Volts on 1 and 6 of V1.
Two of them in series gave 141,3 Volts.More of them became to big to fit in.
You guessed it;they are 22K resistors
i wish i knew the math behind all this .Guess it`s Mouser time.
Ed
Ed
				Ed de Jager
update
Hi all,i tried out the following resistors:220K,330K and 470K.
They all were the AB CC`s 1 watt so i just tried them out for the sake of getting to know the effect of them.
With 220K:V1-1-190V,V1-6-182,2V.
V2-1-193,1V V2-6-199V
V3-1-313V V3-6-287V
With 330K:V1-1-190,4V V1-6-198,4V
V2-1-199,4V V2-6-205V
With 470K V1-1-199,6V V1-6-203 V
V2-1-203,6V V2-6-209,4V
V3-6-290V.
As you can see a 470K resistor is needed to bring the voltages up to specs.
I hope this is of some help to someone sometime.
Greetings,Ed
V3-1-313V V3-6-287V
V3-6-290V.
Greetings,Ed
Hi Ed,
Remember, using a bigger resistor changes the load on the string. DUmble used the equivelent of 150K. I would try and keep it as close to 150K as possible and make a small tweak here or there to get the voltages up a tad. No way would I go bigger than your 220K. 190V is fine btw.
Lower the 22K to 20K or 18K to get the V1 and V2 voltage up a hair.
				Ed de Jager
Hi Dogears,thank you VERY much for your answer.
This is my introduction to Dumble and i need all the help i can get.
The 220K is 2 watt;will that be enough?It says 3 watt in the layout i know.
The good thing also is that the resistors needed to raise those voltages i can get here locally.Isn`t the voltage on V1-6 way too low though?
For some reason shops over here aren`t carrying above 22K in 2 or 3 watt.
I know i eventually will have to buy those Dale resistors but i am going step by step
Ed
 Ed
2 watt is fine.    Say you have 310V there.    The voltage drop is the 310V and you can easily calculate the resistor needed.    I think that is .64 of a watt.    1 watt metal oxide may suffice!!
						Ed de Jager wrote:Hi Dogears,thank you VERY much for your answer.
Ed
Hi Ed,
I agree with Dogears. I use 1W resistors here. Just keep 'm away from the e-caps since these do not like heat...
Good luck,
Jelle
Good luck,
Jelle
				Ed de Jager
Thanks guys!
The other resistors in the dropping string have to be 3 watt right?
How do you calculate these things?Is that simply Ohm`s law or is there more to it?
I have a stack of books from the 50`s that used to belong to my Father but they don`t make much sense to me.
I regret i had`t more interest in these things when he was still alive.
Ed
Ed
Ohm's Law E(voltage) = I (current) X R (resistance). In your case you need the power formula P (power) = E X I and since you don't know the "I" restate the formula (remember your algebra) P = (E X E)/R. So for your resistor to ground just plug in the numbers, for a resistor in a string measure the voltage at each end and subtract the lower voltage from the higher and use that number for E.
www.RedPlateAmps.com
