70's style build 100 watt
				dcribbs1412
Got a chassis from a member here(its the Natchis 4 pre hole with D logo)
had to drill a few holes.
Using MC Twin iron.
Trying the internal loop.
progress so far
http://i1018.photobucket.com/albums/af3 ... gen009.jpg
http://i1018.photobucket.com/albums/af3 ... gen006.jpg
Darin
Using MC Twin iron.
progress so far
Darin
Re: 70's style build 100 watt
Nice!
I always wondered about those chassis.
So they are anodized, then silk screened?
How is the gauge of the aluminum?
Man these amps are labor intensive!
Wires wires wires!
Wires wires wires!
				dcribbs1412
Hi TomStructo wrote:Nice!
Wires wires wires!
Got this from a guy that stalled on a build so it had all the tube sockets, pots and a few caps...
Not sure about anodized...screen seems to be on top though.
Been wondering about removing the D logo...not sure(seems kinda cheesy)
Chassis thickness is less than the CE but I think its OK for the weight of the iron.
And what do you mean " labor intensive"...I thought I was done!...crap
 Darin
There have been some members here that used those chassis and kept the Dumble logo on.
You could just put a decal over it rather then try remove it.
The head cab mounting was what I was wondering how to do on this chassis.
Somewhere there is a thread about mounting these. I think typically members have basically built a shelf in their cab and "locked" the chassis in place on the shelf rather than top mount with screws. I think that the issue is that the top lip isn't large enough to hold PEM nuts or any other solution.M Fowler wrote:The head cab mounting was what I was wondering how to do on this chassis.
Mike
Link below has information on how Talbany mounted the chassis to the cab.
https://tubeamparchive.com/viewtopic.ph ... is+chassis
Henry
Henry
						- boldaslove6789
Didn't HAD mount these style chassis from the sides instead of the top?
									Greg D.C.
Can you dig it?
						Can you dig it?
Hi Darin,
Looks like your chassis has holes drilled on the lip.
				dcribbs1412
I used some aircraft nut plates...super100 wrote:Hi Darin,
http://www.ebay.com/itm/Aircraft-nutpla ... 43aea2f7b2
Fairly simple to install.
Seem to fit OK I had to move them over...too close to front edge of cab
I think I got the idea from someone here.
Just finished recapping a '79 or '80 Fender Twin Reverb and it's held to place just as you did Darin, aircraft nut plate, and this is a heavy mother, the 135 watt version with a huge PT (for a twin, that is).dcribbs1412 wrote:I used some aircraft nut plates...super100 wrote:Hi Darin,
Cheers!
Horacio
Play in tune and B#!
I have this same chassis. My twin PT, and OT dont fit so I will have to modify it. Kinda frustrating
That is a bummer!.strato17 wrote:I have this same chassis. My twin PT, and OT dont fit so I will have to modify it. Kinda frustrating
Darin I read that you used MC Twin trannies.
strato17 if you can handle the cost perhaps getting the MC Twin Reverb PT/OT/choke would be better then cutting up the chassis.
				amplifiednation
I recently built a headcab for one of these chassis.  the builder had put in long chassis mount screws that went completely through the chassis in 5 points and bolted into nuts below the chassis.  i'll see if i can find some pictures!!
									Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
				dcribbs1412
Mark/strato17M Fowler wrote:That is a bummer!.strato17 wrote:I have this same chassis. My twin PT, and OT dont fit so I will have to modify it. Kinda frustrating
I did use the MC iron...I had to drill holes for OT and just made the PT mounting holes a little bigger...did not have to cut the PT hole.(seems strange if you have to with a Twin PT)
This chassis takes a little more work to use than the CE chassis, hope its worth it in the end.
Darin
				dcribbs1412
Just an update...
bulb limiter spark test went good, no sound yet
still trying to wrap my head around the loop..trying to use some of the small alpha push/pull pots with caps on them for send and return controls...not sure how to wire them...anyway here's some pics
Darin
Darin
