VVR in Liverpool
ampmike
VVR in Liverpool
Post by ampmike »
Hey Guys,Im probably being repetitive here.Can anybody direct me to vvr installation pictures in a Liverpool.Cant wait too put it in,Thanks,Mikey
ampmike
VVR in Liverpool
Post by ampmike »
Well I did get some instructions from Dana.It looks like a bit more work than the garagetale guy shows.I still would like to see a picture of a Liverpool with one or a least a rocket. :D Patience Mikey
Gibsonman63
Re: VVR in Liverpool
Post by Gibsonman63 »
See if this helps. Compare Dana's instructions with the attachments. This is really the easy one to install because of the cathode biasing of the power tubes. The VVR goes in the power supply string and you add a couple of blocking capacitors. I moved the resistor from the input jack to the first preamp tube.
Gibsonman63
Another couple of shots. The third capacitor from the left is the blocking cap between C6 and V1a, pin 2. Note that mine is a little different because I paralleled the first preamp stage so on the picture it is wired to the second preamp tube.
Gibsonman63
BTW, I used the thermal compound on mine because I assumed that it was required. There is another recent thread where Dana makes a compelling arguement for not using the thermal compound. Mine works fine with it.
ampmike
vvr in Liverpool
Post by ampmike »
Thank you very much,Im going to work on it today and Ill post some results,In the mean time I better look into the thermal glue, Is artic silver five OK for the VVR?,Mikey
markr14850
Re: vvr in Liverpool
Post by markr14850 »
ampmike wrote:Is artic silver five OK for the VVR?
Probably not. AFAIK, it's electrically conductive.
You might want to try a sil-pad instead. Unlike mica, they don't need thermal grease.
Here are a few that fit a TO-3P casing:
http://www.mouser.com/Thermal-Managemen ... 3p&FS=True
UR12
Post by UR12 »
Here are a few pics of a Liverpool (Ginger Clone) amp I built 6 years ago in 2006. Ginger was Ken's first Liverpool and had a 1/2 power switch that really wasn't all that usefull. I removed the 1/2 power switch and installed the older VVR2. If you go with the smaller filter caps you can just squeeze it in. The newer smaller VVR is easier to mount. BTW this amp has been used a lot over the years and the VVR is still functioning without fail.
ampmike
vvr in Liverpool
Post by ampmike »
Thank You Dana,Thanks to all you guys,I really feel the Liverpool is my favorite.Its just right for me and I cant wait or maybe my family cant wait for me to install the VVR.Dave aka Colossal is helping me install the vvr.Happy 4th to all of you here at TAD.These pictures are awesomeI will eventully switch over all my amps to vvr"s.!!!!Mikey Dana,Is that a bias pot on your board?
Colossal
Post by Colossal »
ampmike wrote:Thank You Dana,Thanks to all you guys,I really feel the Liverpool is my favorite.Its just right for me and I cant wait or maybe my family cant wait for me to install the VVR.Dave aka Colossal is helping me install the vvr.Happy 4th to all of you here at TAD.These pictures are awesomeI will eventully switch over all my amps to vvr"s.!!!!Mikey Dana,Is that a bias pot on your board?
Dana, thanks for posting the photos! Sweet build. The photos will make the install so much easier for Mike. [Pointing at the photos above...] Mikey, we need to do that to your amp! :lol:
lol Mike is all hyped up and raring to go on this.. just a guess.
UR12
Post by UR12 »
ampmike wrote: Dana,Is that a bias pot on your board?
No, That is a trim pot I installed in place of the 150k to dial in the third gain stage. it also has an adjustable line out on the back.
