doveman wrote:I used the silicon wafer that comes with it.
Are you sure it was silicon
e, because in the picture in your first post, it looks a bit like a mica one. (Silicone = floppy rubber that can be used without compound; Mica - hard, brittle & needs heatsink compound). AFAIK, the NTE2973 is in an electrically insulated package, anyway, so doesn't need the mica, just the heatsink compound/pad.
I don't know KT66s, so I'm not sure what you biased your amp at - guessing at no more than 50mA per tube say?? roughly 450V B+ ?? that's 45W from the PSU - 50W, say with the preamp tubes.
From the NTE2973 datasheet, it has a maximum junction temperature of 150°C, and a thermal resistance from junction to case of 0.45°C/W
The Mosfet should (I think) only ever see about half of the 50W, but taking worst case, if it was dissipating the full 50W, it would live, provided the case stayed at 150 - (0.45 * 50) = 127°C. Taking off another 0.5°C/W for the silicone washer assuming that's what it is) means the chassis will be at 127 - (0.5 * 50) ~ 100°C - Spit would sizzle on your amp chassis before the MOSFET blew if it was in good thermal contact with the case - is that how it ran?
To specify a heatsink, I would aim for a 125°C max junction temperature (a bit conservative). For 25W dissipation (the likely 'real' case) this means a max case temperature of 125-(0.45 * 25) = 108°C. The ambient temperature might be ~38°C (for round numbers), this means any heatsink needs to limit temperature rise to 70°C above ambient for 25W dissipation, or 2.8°C/W. Allow 0.5°C/W for the thermal resistance of the mounting arrangements, and any heatsink needs to be better than ~ 2.3°C/W.
Your chassis probably wouldn't be that good, especially if it is thin-ish metal. If it was ~3mm , my gut feel would be that it *might* be OK. I don't think moving the MOSFET would make a tremendous difference, personally. (Adding a second one in parallel, mounted on a completely different part of the chassis might work, though).
The sort of thing you would be looking at for a stand-alone heatsink would be very roughly a 4" x 4" finned heatsink , vertically mounted, with the fins also vertical and in free air. (Many other permutations are possible.)
Have a look at what's available and pick something suitably rated to fit into whatever space you have available - manufacturers quote the °C/W figure for their heat sinks, but pay attention to the orientation that they're rated for, and the temperature rise above ambient that they assume (if it's lower than the 70°C above ambient assumed above it's OK). If you mount the MOSFET inside the chassis, with the heatsink outside, you will gain some heatsinking from the chassis provided you use thermal compound / silicone pads either side of the chassis.
If you're prepared to go to fan cooling, you'll be laughing.
HTH
Andy
