5F6a importance of output configuration
Baltar
Post by Baltar »
Moved to Technical section
Baltar
Re: 5F6a importance of output configuration
Post by Baltar »
looks like my post is gone, so once more..
Hi again,
i'd like to try a 5f6a bassman in 6v6 configuration.
i thought about lowering voltage by using a 5y3.
due to 6k6:2r trannies are rare i'd use a deluxe reverb-ot
i still have in stock, which would require to wire the
speakers in series/parallel config to 8r.
what do you think - is it worth a try, or would the
amount of sonical influencing changes(tubes, tranny,
speaker response) result in something, that sounds very
different to a bassman?
cheers, B
Jana
Post by Jana »
I say go for it. If you can get the B+ to be around 350 to 380 or so, I think that will be a nice sounding amp. I think that would be a nice clubbing amp.
Baltar
Post by Baltar »
thanks for you opinion.
i'm going to design the power supply-6l6-like and just alter
the rectifier, tubes, and ot. so in case i want to, the upgrade would
be easy.
Sorry about that Baltar, I didn't realize I had deleted your text.
I'm still learning which buttons to push. :lol:
Baltar
Post by Baltar »
no worries :) thanks for moving
renshen1957
Post by renshen1957 »
Baltar wrote:looks like my post is gone, so once more..
Hi again,
cheers, B
Hi,
Some would worry more about the the B+ voltage than the Output Transformer. Kelley used a higher B+ and a circa 4k2 ohm OT on his 4 6V6 FACS. I have run 6V6 tubes in Bassman Transformers. You can run 6V6 tubes at a lower OT primary, your distortion will be higher, but in a guitar amp distortion is good.
Some of the newer 6V6 tubes can handle higher voltage.
Some things to consider as to rectifier tubes:
How much mA current the tube can handle.
Check out http://www.300guitars.com/articles/rect ... drop-chart
Regards,
Steve
rp
Post by rp »
Structo wrote:I'm still learning which buttons to push. :lol:
Tom, the wrong button could definitely be trouble! Here's a safety primer for you:
http://www.youtube.com/watch?v=6MMkiq8Kxis
Baltar, I'm thinking you want to keep the preamp voltages and PI close to 5F6A / JTM45 level for best sound, so you might have to play with the power string.
tubeswell
Post by tubeswell »
Well you could also do a 5F6A with 4 x 6V6 and then you could use the same OT.
As far as the PT goes, 2 x 6V6 should work well with a 5Y3G or a 5R4 from a 325-0-325VAC secondary
Baltar
Post by Baltar »
@Steve
thanks a lot for the helpful link.
i like the electro harmonix 6v6 a lot and like to try those first in my build.
they are indeed voltage critical, other than eg jjs
@rp
good point, i will do
@tubeswell
don't tempt me :)
idea on one pair of 6v6 was to save some power and weight(smaller trans
if possible) still haven't decided for the pt yet, but am thinking of a 290dex
