JCM TSL 100 Hum issue
Markusv
Post by Markusv »
Folks
Hope you can help
I have a JCM2000 TSL 100 on the bench with steady hum
Pulled all the 12 ax 7 tubes so not there (pre-amp)
There is no improvement with the reverb disconnected
Voltages seem OK
Any suggestions?
I did my chopsticking for loose connections etc. Do anyone of you know of typical failures in these amps?
Do I strat to suspect filter caps?
Thank you in advance
Markus V
.........Now where did I put it?
Re: JCM TSL 100 Hum issue
Can you tell if it is 60Hz or 120Hz?
Markusv
Post by Markusv »
Thanks Tom
So a grounding issue with a bad guitar cable for instance is 60 cycle - right?
That is a buzzy type hum
This is more of a soft drone
Not sure but does that seem like 120 cycle?
Markus
Firestorm
Post by Firestorm »
Maybe check to see that everything that is supposed to be at ground really is. Ground gets "passed" from board to board so maybe a bad connector. Different amp, but I've seen a JCM900 where the ground trace burned itself open and it hummed like hell.
Well what I was getting at is that most of the time a 60Hz hum will be something in the power supply, like a bad cap or other component that is letting the AC through.
The 120Hz hum is generally from heater wiring.\
Here is a pretty good troubleshooting flow chart for tracking down sources of hum.
http://www.geofex.com/ampdbug/hum.htm
Markusv
Post by Markusv »
Thanks to all who replied
I will be looking at this amp again today and let you know. I will see if I can narrrow it down with a scope
Markus
You need a spatula scope.
I use a little art/painting spatula wrapped in electrical tape. The wooden handle is removed. You hold it in your hand, and hover over areas of the amp listening for similar noise or additional similar noise.. or just noise, or whatever.
That helps me find problems like that one sometimes.
Play a Bb on the low E string and pull it slightly sharp. Does the note match the hum?
Markusv
Post by Markusv »
Reeltarded wrote:You need a spatula scope.
Thanks Reeltarded!!
So if it matches the sharp'ish B flat - then what does it indicate for you?
I'm not in front of the amp now but I think you're onto something
Markus
60hz is Bb bent a little sharp.
Markusv
Post by Markusv »
Reeltarded wrote:60hz is Bb bent a little sharp.
So in that case I could suspect power supply issues - right?
Wiggling the connectors or cleaning them doesn't help?
Tubes pulled? Hrrrmm..
